I'm currently designing an LLC resonant DC/DC converter with 12V input, +/-15V output and nominal 200W combined output power. I've already got my resonant circuit, transformer, gain curves and power stages working and optimized.
Right now I'm designing the converter's feedback loop. I'd like to use Bang-Bang charge control to turn the converter into a first-order lowpass, as that makes compensation really easy.
Here's my circuit (please excuse the huge image):
LTSpice ASC file (Github Gist)
The problem I'm having is that the circuit works absolutely perfectly, but I don't quite understand why. Specifically, I just don't see the negative feedback mechanism that keeps the duty cycle at 50% (and, therefore, the DC offset across the resonant tank circuit at zero).
To check if there really is a feedback mechanism (and I haven't just gotten lucky in the simulation), I added a voltage source Vdc_error
in series with the resonant tank circuit. This voltage source is initially zero and adds a huge DC voltage offset at t=3ms (red trace in the simulation plot). As can be seen from the green trace (PWM waveform), the duty cycle initially deviates from 50% once the offset has been added but returns to 50% just one cycle later, which means that there really is a strong negative feedback pushing the duty cycle towards 50%. (This, in turn, then also compensates the DC offset by putting -5V onto Cres
to cancel out the 5V from Vdc_error
Unfortunately, I just know that the negative feedback exists (and that's a good thing), but I'd also like to know how this negative feedback happens. The only feedback path in this circuit is via transformer L6/L7/L8
, which I use to measure the resonant capacitor voltage to implement the aforementioned Bang-Bang charge control scheme. However, since this is a transformer, the feedback signal is AC-coupled, which means that it simply can't see the DC offset voltage on Cres
. Yet the circuit is still able to perfectly compensate for DC offset in the resonant tank circuit somehow. Even adding a voltage ramp in series with Cres
doesn't trip it up; the overall offset voltage stays exactly at zero.
TL;DR: Where's the negative feedback path in this circuit that keeps the duty cycle at 50% and DC offset at zero, and how does it work? I might just be blind, but I can't see it.
Edit: This is what the capsense transformer feedback voltage looks like when the Vdc_error
voltage gets applied. It's quite easy to see that it becomes asymmetric at that moment in time. The capsense transformer is good enough to reproduce the asymmetric waveform accurately during the time it takes the converter to restore 50% duty cycle again, so it's not the capsense transformer itself that forces symmetry. (The DC current that the asymmetric feedback signal causes in the transformer's primary also doesn't reach a value that's high enough to make it saturate. Its frequency response is flat down to low enough frequencies to reproduce it, too.)
