It's not a short circuit; the path is from positive supply, through an inductor, then through a MOSFET and back to the negative terminal of the supply.
Only if the MOSFET was permanently enabled might it be regarded as a short circuit. However, for normal MOSFET operation, when activated, the current through the inductor ramps up storing magnetic energy then, when the MOSFET deactivates, that stored energy is released to the "work coil" which resonates and generates eddy currents in the work-piece (not shown).
Ditto the other MOSFET circuit (and its associated inductor) but, it operates alternately to the first MOSFET circuit due to the way D3 and D4 are cross-coupled.
Don't try and use it at powers more than a hundred watts or so until you are happy the MOSFETs are not getting too warm.
