I'm confused about the theory of earthing in mains electrics. In particular, how the potential of "earth", the ground or literally the soil beneath my feet relates to the live and neutral wires in household circuits. I am in the UK and would like to discuss UK mains.
So, I've always understood that earthing is an important safety precaution. The earth pins on mains sockets terminate somewhere connected to earth, perhaps via a metal rod stuck into the ground. Metal components of electric appliances are connected to the earth pin on their plug, so that if there is a short anywhere in the appliance, the current would flow straight to earth rather than through a person touching the appliance. This is because the resistance between the appliance and earth is much lower across the earth wire than across the person.
Now, I had compartmentalised the idea that current wants to flow towards earth. I had just taken this for granted, without asking why.
I found out that actually the neutral wire will at some point be "tied" to earth. I think this "some point" can be near the home, maybe even in the home? Or it can be near the transformer? Either way, neutral is actually connected to ground.
So does this mean that the potential of the earth is actually oscillating 180 degrees offset from the live wire in every home, with a potential of 240V between them? This would then explain to me why current wants to flow from live to earth, and how earthing electrical appliances protects a person from shock in-case of a short, but it raises other questions for me ...
- We seem to be relying on soil being a very good electrical conductor. For example, in the extreme case, where the neutral is connected to earth near the transformer, for the earth to be 240V relative to live wires in all the associated homes and safely source current in the case of a shorting, then the soil/earth/ground would need to very effectively conduct to the surrounding homes, no? This seems very unlikely to me. Is soil in-fact a fantastic electrical conductor or have I missed something?
- Would it not be safer, in some ways, not to tie neutral to earth, and do away with the earth wire? In this scenario, if a person touches anything that is connected to live, then maybe there wouldn't be any voltage across them because it's now just a "floating" voltage relative to ground?
- If the PD between earth and neutral is 0, then why even bother with neutral? Why not just connect the negative source of the transformer to earth and replace neutral wire with earth in the home. This would save the cost of cabling and you could still protect from shock by connecting metal appliance bodies to the earth wire as well?
