What would happen if I pull down the INH pin of this IC to GND?
I am unable to understand what would happen if I pulled to GND or make it HIGH?
Can someone help me ?
It's an output (not an input) so I wouldn't go pulling it low in case the internal PMOS is trying to connect it to +Vsupply. From the data sheet page 8: -
The inhibit pin provides an internal switch toward the VS pin which is protected by temperature monitoring. If the device is in normal or Fail-Safe mode, the inhibit high-side switch is turned on. When the device is in Sleep mode, the inhibit switch is turned off, thus disabling the voltage regulator or other connected external devices.
