I commonly use 30ga Kynar (Polyvinylidene Fluoride, PVDF) wire for PCB <=24 VDC repairs.
But can it be used to repair 120 VAC signal wires?
Strangely, vendors do not seem to publish a voltage rating for Kynar wire:
- https://www.mcmaster.com/3113N6/
- https://wesbellwireandcable.com/products/hook-up-wire/kynar-wire/kynar-wire-wrap-30/
- https://www.awcwire.com/product/kyn30-1
- https://jonard.com/wire-wrap-wire-kynar-and-tefzel?v=429 (Voltage: Not Rated?)
Researching, PVDF has a Dielectric strength (at 23°C) of 1.4 – 110 kV/mm
. That's quite a range.
Assuming the low-end of that range, and given that the insulation dia of one 30ga Kynar wire is about .020 in (0.50 mm), does that imply an insulation resistance of 700 V for this wire?
