I have a question and a solution, I don’t know how the solution came up with the variables and values highlighted in blue in the solution part.
Question: enter image description here
Solution: enter image description here
Tim Williams
  • 22,874
  • 71
zappi
It's a flat, 2 dimensional plan wave. You have to transform the description to spherical co-ordinates.
By inspection, we see that phi is zero: (it's a plane wave so it's tangential to any point reference). and that the TEM wave angle is a multiple of 45 degrees: (it's got two components of equal magnitude at right angles).
So X and Y are the x:y magnitudes of the vector. z is the magnitude of the combined vector.
It's not a convention I'm familiar with, but our professor had realized that mathematically there was a simpler way of deriving and describing TEM waves that did not require the use of historical concepts like "wave vector", so we didn't spend a lot of time on "wave vectors".
david
  • 4,364
  • 30
  • hi david thankyou for clarifying, is it possible to have a sort of visual image so that it is fully clear? – zappi Oct 18 '22 at 14:40
