I've often heard that trench MOSFETs have a narrower FBSOA than planar MOSFETs due to their cell design. The explanation I've commonly seen is that the cell design has a negative Rds(on) temperature coefficient, so if a single cell gets warmer than the others it has a tendency to receive a greater proportion of the current and go into thermal runaway. I've heard this referred to as the Spirito effect in the context of operating MOSFETs in a linear manner.
The implication appears to be that the runaway behaviour arises from the trench MOSFET being constructed from lots of smaller MOSFET "cells" in parallel. However, given descriptions I've seen of planar MOSFET construction, they don't seem to be constructed from one single monolithic cell. The literature refers to planar MOSFETs as having gates, plural, in practice. It isn't clear to me why there is such a distinction between the two from a thermal runaway perspective.
I've also read that the narrow FBSOA of trench MOSFETs is in part due to the lower Rds(on) causing a "higher point of intersection between two transfer curves at different temperatures". This was sourced to "Improved SOA analysis for trench MOSFETs using the Spirito approach" by Kwan et. al., but I was unable to find the original material being referenced. This statement is unclear to me. My rough intuition is that this is about a current equilibrium between cells not being reached until a higher temperature, but it feels a bit vague.
Could someone shed some light on this? What aspect(s) of the trench construction cause this difference in thermal runaway behaviour? Why are planar MOSFETs considered more immune to these behaviours? And what is meant by the higher point of intersection between the transfer curves?
