What is the difference between arsenic and phosphorus in IC fabrication technology? When do we prefer one of them over the other?
JRE
  • 67,678
  • 179
mohammad rezza
  • 442
    Seemingly this is better to transfer this question to physics forum. – mohammad rezza Oct 12 '22 at 14:32
    just delete your question and ask at physics SE – jsotola Oct 12 '22 at 15:05
  • Well i think a more suitable site would be Manufacturing Engineering or something like that. – Miss Mulan Oct 12 '22 at 17:06
    I honestly think semiconductor design and theory is EE. don't really see how "in which EE applications do I need either type of doting" is more on topic over at physics than here. (Also, this is 5th semester course level at multiple EE programs I'm aware of, another indication of brings to the engineering field) – Marcus Müller Oct 12 '22 at 20:30
    https://www.cityu.edu.hk/phy/appkchu/AP6120/8.PDF – Bruce Abbott Oct 12 '22 at 21:34
    @mohammadrezza It has to do with the process (recipes, equipment, temperatures and step durations used, etc.) But another factor has to do with safety and handling, as well. While all gases used are usually toxic, arsine is **extremely** toxic when released in the air and it does NOT degrade with time. It is relatively stable in an oxygen atmosphere. A small canister ($50 worth) can kill about 3000 people. Phosphine is, on the other hand, less toxic but **extremely** pyrophoric. A terrible fire hazard anytime that stuff is around. Safety is another factor in choice, I suspect. – jonk Oct 12 '22 at 23:17
The answer will depend on the semiconductor. This answer applies to silicon.
Both are n type dopants. So at first you might think they are interchangeable, and to some extent they are. But they have other properties that leads to picking one over the other.
Arsenic is much heavier/bigger than phosphorus. This means it will implant shallower and diffuse less. If you want a very shallow implant, arsenic is your friend. This is probably the biggest difference most people care about.
Other important differences include:
  • How much of the dopant you can activate, which affects maximum effective dopant concentration.
  • Energy of the dopant levels within the bandgap. Arsenic is a moderately deep dopant. Operating at lower temperatures may not fully ionize the arsenic.
Matt
  • 1,689
