I am working on a project in which I need to amplify a 0-3.3 V DAC output to 0-500 V (or to 0-200 V if 500 V iss too much to ask) and I need to draw up to 100 mA current out of this output. I also need to mention that my DAC output signal will probably have a maximum frequency of 10 kHz.
I have never worked with high voltages like these, compared to digital levels, so I'm open to any suggestions, methods, parts, etc.
ocrdu
  • 8,705
  • 30
  • 42
spinmaster
  • 141
  • If you need only AC, why not think about transformer output coupling? – tobalt Oct 08 '22 at 06:30
    DAC outputs a sine wave at 10 kHz or ... DAC samples every 100 us? – Antonio51 Oct 08 '22 at 06:33
    I think I would find a way to use some type of programmable bench supply. – user57037 Oct 08 '22 at 08:42
    Does the output need to produce a DC level as well as an AC signal <-- full details please. – Andy aka Oct 08 '22 at 09:07
  • Is the 500/200 V signal "just a signal", or is it a voltage supply? With different words: do you have additionally a 500+ / 200+ V DC supply? – virolino Oct 08 '22 at 10:11
    drawing 100 mA from a 200 V source means you have 20 W output power. This implies a heavy load, and probably means you need to think about protection against reactive properties of the load. What is your load? This, as is, a relative harsh requirement, and the more specifically you can tailor the circuit to the load, the easier it might get! – Marcus Müller Oct 08 '22 at 13:08
    @mkeith Even easier, I know Stanford Research makes some high-voltage power supplies that can be controlled with an analog signal--which basically makes them high-voltage, low-frequency amplifiers. – Hearth Oct 08 '22 at 14:34
SAFETY first ... High Voltage ...
Be aware that High Voltage BJT is not very usual. (to be replaced by MOSFET ...)
Made with FREE microcap v12, link.
Here is an example of a such simple "analog" circuit (current limited).
NB: Must be checked deeply (All Voltages, Currents, Powers).
The labelled transistors shown here are NOT suitable ...
Tried with TIP47, should be ok. I added a BJT for current protection.
Here, the link to the new file.
Here is an example with MOSFETs.
Under the same conditions (all checking) as above ...
Voltage and current versus Voltage control (parameter Load: shorted -> 2k).
Powers dissipated by MOSFETs.
With some adjustments, TRAN analysis ...
NB: simultaneous stepping on Voltage control and Load R6 (working at same max current).
This shows different "slew-rate" of rising voltages.
NB: using BUZ41 MOSFET is 3 times faster. Power not checked.
Antonio51
  • 11,004
    If this is for an experimental project where you can use salvaged parts: High voltage BJTs are quite common in cheaper, older SMPS and in most anything with a CRT in it. For an extra quirky solution, use a vacuum tube :) Be aware that even high voltage BJTs can NOT stand emitter voltage going significantly above base voltage (which can easily happen with capacitive loads).... – rackandboneman Oct 09 '22 at 12:00
  • Which SPICE simulator have you used in your simulations above? Thank you! – jose.angel.jimenez Oct 14 '22 at 10:42
  • @jose.angel.jimenez FREE microcap v12, I add in answer. – Antonio51 Oct 14 '22 at 13:07
A 50 watt DC coupled audio amplifier would do the job, although 200-500 volts would be rather special.
Apex makes some high power amplifier modules that might be just what you need:
https://www.apexanalog.com/products/linear_selector.html
PStechPaul
  • 7,195
    Ordinary audio amplifier feeding a vacuum tube audio output transformer in reverse. Done that once. – John Doty Oct 08 '22 at 18:50
  • I had considered that, but the output of a DAC is usually DC, so a transformer would not work. I also considered using a tube amplifier, without the output transformer, which would likely have a B+ of at least 200 volts. – PStechPaul Oct 08 '22 at 19:51
    @PStechPaul DC vs AC is only a simplification of how to analyze circuits. A DAC outputs voltages at points in time. If those voltages are modulated as a sign wave over time, then the output of the DAC is better considered as an AC signal than a DC signal. (Theres also a matter of DC bias, but if you use a bipolar DAC, that can be ignored). This is a standard way of analyzing audio circuitry. – user1937198 Oct 09 '22 at 02:23
  • As an example of this, most PC sound cards use capacitors in series on all their line outputs after the DACs. Yet a capacitor in series blocks DC signals.This is because any change in voltage over time can be considered a transient superposition of AC signals, and so the capacitor conducts the change in voltages. – user1937198 Oct 09 '22 at 02:27
What you need is an amplifier. It does not have to be a particularly good amplifier, as you can add negative feedback to make it accurate at the low frequencies.
Because your power level is quite high (50W), Class D amplifier would be a good choice, for its efficiency and low amount of waste heat. It works similarly to switching mode DC-DC converters.
Easiest way to make a class D amplifier is to take a 500 VDC supply voltage, a MOSFET half bridge rated to that voltage and an output filter made of inductors and capacitors. Instead of a DAC, most straight forward way would be to use a microcontroller PWM pin to drive the H-bridge. The duty cycle determines the output voltage, and you will want the PWM frequency to be about 10x the analog bandwidth you want at the output.
If you only have an analog input signal, a sigma-delta modulator IC can be used to convert it to PDM signal. If the output noise level is important, PDM can give less noise than PWM in a microcontroller implementation also.
After the half bridge, you have a square wave that alternates between 0 and 500 VDC, having the average level of your target signal. To filter out the high frequency square wave components, you can use 1 to 3 stages of LC lowpass filters.
jpa
  • 6,804
  • 32
    A class D amplifier will certainly be more efficient, but unless one can be found off-the-shelf, it is a rather major circuit design project. Using a high voltage power op-amp (class B) for 50 watts output is a simple solution, and should be able to achieve at least 70% efficiency, so it is only necessary to dissipate about 15-20 watts of heat. https://www.elprocus.com/class-b-amplifier/ – PStechPaul Oct 09 '22 at 21:50
    @PStechPaul That 70% efficiency is true only for sine wave at maximum peak voltage. For e.g. DC output at 5 VDC & 100 mA, the efficiency of a class B amplifier is only 1%, with 49.5 W dissipated. – jpa Oct 10 '22 at 05:06
    Yes, that is true. But the OP indicated that the DAC would be providing an AC signal, and presumably at or near the voltages required (200 to 500 volts). If a lower voltage is required, the supply rails might be made adjustable. In any case, the maximum power dissipated by the linear op-amp would be 50 watts, easily handled by an adequate heat sink and fan cooling. Unfortunately, the OP @spinmaster has not provided additional feedback and the topic is being closed. – PStechPaul Oct 10 '22 at 08:18
    @PStechPaul I agree that there are a lot of details missing in the question. And it is true that 50W is easy enough to cool with a fan. – jpa Oct 10 '22 at 08:31
  • @PStechPaul A class D amplifier output can drive a relatively compact transformer to step up the voltage. The amplifier would be an integrated solution, and a couple of them could be paralleled as needed. – Kuba hasn't forgotten Monica Oct 11 '22 at 06:26
    But the OP implies that they want to use a 0-3.3 volt DAC signal to get 0-200 or 0-500 volts, which would require DC coupling. However, the OP has not replied, so details are missing. – PStechPaul Oct 11 '22 at 06:35
