I am using CCS 5.x on Windows 7. The TI board is LM4f232. The following code performs A to D conversion of the on-board accelerometer. I am trying to use printf to see my variable values, but it is failing.
#include "utils/ustdlib.h"
#include "inc/hw_types.h"
#include "driverlib/adc.h"
#include "inc/hw_memmap.h"
#include "driverlib/sysctl.h"
#include "driverlib/pin_map.h"
#include "driverlib/gpio.h"
#include "stdio.h"
#ifdef DEBUG
void
__error__(char *pcFilename, unsigned long ulLine)
#endif
int main(void)
unsigned long ulADC0_Value[3]; //holds ADC output values
//Configure the system clock to 50MHz
SysCtlClockSet(SYSCTL_SYSDIV_4|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN);
//GPIO Configuration
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6);
//ADC Configuration starts here
SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
ADCSequenceConfigure(ADC0_BASE, 0, ADC_TRIGGER_PROCESSOR, 0);
ADCSequenceStepConfigure(ADC0_BASE, 0, 0, ADC_CTL_CH8);
ADCSequenceStepConfigure(ADC0_BASE, 0, 1, ADC_CTL_CH9);
ADCSequenceStepConfigure(ADC0_BASE, 0, 2, ADC_CTL_CH21 | ADC_CTL_IE | ADC_CTL_END);
ADCSequenceEnable(ADC0_BASE, 0);
//ADC measurement is made here
while(1)
//trigger ADC measurement
ADCProcessorTrigger(ADC0_BASE, 0);
//wait for the conversion to complete
while(!ADCIntStatus(ADC0_BASE, 0, false))
//transfer data from FIFO to local variable
ADCSequenceDataGet(ADC0_BASE, 0, ulADC0_Value);
// this line creates problem
printf("values %l", ulADC0_Value[0]);
//Delay between samples
SysCtlDelay(SysCtlClockGet() / 12);
The following is the content of my startup_ccs.c file (some part is clipped)
// startup_ccs.c - Startup code for use with TI's Code Composer Studio.
// Copyright (c) 2011-2012 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 9107 of the EK-LM4F232 Firmware Package.
// Forward declaration of the default fault handlers.
void ResetISR(void);
static void NmiSR(void);
static void FaultISR(void);
static void IntDefaultHandler(void);
// External declaration for the reset handler that is to be called when the
// processor is started
extern void _c_int00(void);
// Linker variable that marks the top of the stack.
extern unsigned long __STACK_TOP;
// The vector table. Note that the proper constructs must be placed on this to
// ensure that it ends up at physical address 0x0000.0000 or at the start of
// the program if located at a start address other than 0.
#pragma DATA_SECTION(g_pfnVectors, ".intvecs")
void (* const g_pfnVectors[])(void) =
(void (*)(void))((unsigned long)&__STACK_TOP),
// The initial stack pointer
ResetISR, // The reset handler
NmiSR, // The NMI handler
IntDefaultHandler, // FPU
IntDefaultHandler, // PECI 0
IntDefaultHandler, // LPC 0
IntDefaultHandler, // GPIO Port R
IntDefaultHandler, // GPIO Port S
IntDefaultHandler, // PWM 1 Generator 0
IntDefaultHandler, // PWM 1 Generator 1
IntDefaultHandler, // PWM 1 Generator 2
IntDefaultHandler, // PWM 1 Generator 3
IntDefaultHandler // PWM 1 Fault
// This is the code that gets called when the processor first starts execution
// following a reset event. Only the absolutely necessary set is performed,
// after which the application supplied entry() routine is called. Any fancy
// actions (such as making decisions based on the reset cause register, and
// resetting the bits in that register) are left solely in the hands of the
// application.
void
ResetISR(void)
// Jump to the CCS C initialization routine. This will enable the
// floating-point unit as well, so that does not need to be done here.
__asm(" .global _c_int00\n"
" b.w _c_int00");
// This is the code that gets called when the processor receives a NMI. This
// simply enters an infinite loop, preserving the system state for examination
// by a debugger.
static void
NmiSR(void)
// Enter an infinite loop.
while(1)
// This is the code that gets called when the processor receives a fault
// interrupt. This simply enters an infinite loop, preserving the system state
// for examination by a debugger.
static void
FaultISR(void)
while(1)
// This is the code that gets called when the processor receives an unexpected
static void
// Go into an infinite loop.
while(1)
Whenever I put printf:
printf("values %lu", ulADC0_Value[0]);
and even
shown in my first code after ADCSequenceDataGet(), the program stops, and the control goes to the following section in startup_css.c:
static void
FaultISR(void)
while(1)
I followed the instructions given here on printf support and increased the heap size to 500 bytes, but still I am not able to print the variable values on console. What is wrong with my code?
