I'm connecting a EC11E rotary encoder to a Adafruit Feather 32u4 Bluefruit LE. The EC11 has 5 pins: 2 for the switch, and 2 for the knob.
Connecting the encoder itself would be easy, but I'm having a hard time finding out how to add debouncing capacitors and resistors.
This is the schematic I've found to be best but I'm not sure about the numbers; some schematics use 100 nF and 1 kΩ while others use 10 nF and 10 kΩ. What difference do these numbers make to the signal?
ec11 schematic
ocrdu
  • 8,705
  • 30
  • 42
kid
  • 101
  • Does this answer your question? [Does EC11 Incremental Encoder need hardware debouncing and VCC for encoder?](https://electronics.stackexchange.com/questions/512042/does-ec11-incremental-encoder-need-hardware-debouncing-and-vcc-for-encoder) – jonathanjo Oct 03 '22 at 08:04
  • So from my understanding, the lower the resistor resistance the better? And higher capacitance the better? – kid Oct 03 '22 at 08:43
  • Debouncing should be done in your software. The R and C should help with ESD. – Kartman Oct 03 '22 at 11:24
  • So what values should R and C be? – kid Oct 03 '22 at 11:48
    Not super critical. The ones in the schematic should be adequate. – Kartman Oct 03 '22 at 12:30
  • What is important is the *time constant* (R*C). It needs to be long enough to filter the bounce, but short enough so the software won't miss fast user input. – Mattman944 Oct 03 '22 at 13:19
  • Also see answers here: https://electronics.stackexchange.com/questions/632802/raspberry-pi-not-reading-rotary-encoder-accurately/632809#632809 – Mattman944 Oct 03 '22 at 13:34
  • Does this answer your question? [How do you pick component values for a debouncing filter?](https://electronics.stackexchange.com/questions/423688/how-do-you-pick-component-values-for-a-debouncing-filter) – Tim Williams Oct 16 '22 at 14:28
0 Answers0
