How can a vacuum cleaner say it's 3 hp, yet only be rated at 1200 W since 1 hp is ~750 W?
The product description says it has a "3 horsepower motor" and that 3 hp is the peak.
They're lying to you, vacuum cleaner motors spend most of their time running at near peak power. (when you block the hose and hear motor go faster it's using less power)
1300W universal motor, about 80% efficient, about 1.5 horsepower.
Maybe it's a 3HP motor in some other application (like driving a mechanical load), but driving a centrifugal blower its max load will be with a clear air path.
In the United States wet/dry vacuums cleaners (typically called Shop Vacs) are rated using horsepower. This horsepower rating is not the actual power output of the motor. It has no physical meaning and can ONLY be used to compare with other vacuums.
It is NOT the 1 second or 6 second or 15 second or 30 second peak power. There is absolutely no way you can connect a 3 horsepower vacuum cleaner motor to a dynamometer and measure 3 mechanical horsepower at the shaft or output. It is not even based on stall torque * no-load speed. It is basically a meaningless number, except that a 5 HP vacuum from Brand A will probably be more powerful than a 3 HP vacuum from Brand A.
This is probably peak power, which for universal motors can easily be two to three times nominal power rating. Motors and transformers generally can be overloaded for short time duty cycles based on I2t heating of the winding resistance, so for example:
1x continuous
1.4x 50% duty cycle (30 seconds ON, 30 seconds OFF)
2x 25% duty cycle (15 seconds ON, 45 seconds OFF)
3x 10% duty cycle (6 seconds ON, 54 seconds OFF)
https://electricalmag.com/universal-motor-characteristics-speed/
https://www.routerforums.com/threads/peak-horsepower-vs-real-horsepower.26428/
