Apparently you can't run 7.4V servos through this.
Anyone know what chip I blew up? Trying to work out if I can fix it or need to buy another PCA9685.
Thanks
Thanks
Most likely both the PCA9685 and the SOT23 P-channel reverse-protection MOSFET (which is looking quite toasted). In terms of what happened, the PCA9685 probably failed short first, which caused excessive voltage drop across the MOSFET and the resulting power dissipation killed it dead.
Given the prices of such modules, you're probably better off just replacing it.
In the Adafruit schematic the transistor is an AOD417. This will be something else, such as an AO3401A, since AOD417 is in a TO252 package.
It's the sot 23 package up by the silk screen marked power. My guess is it's either a mosfet for a pull-up or a voltage regulator supplying a specific voltage on the board.
You'll need to find out what the part markings are on it to replace it.
The best thing to do would be to find out what voltage is the parts needs and supply the correct voltage and see if you're getting the correct voltage to the Vcc pins on each part
