Can you please help me getting width of theese golden fingers and what those text in red rectangle means?
It is M.2 connector with E key.
The text in the red box means that that side has 34 contacts, each one is 0.35mm +/- 0.04mm wide, with center spacing at 0.5mm. Each contact extends 2mm from the end of the board. The reason they're not shown going all the way down to the bottom is because of the board bevel, which is specified at 20 +/- 5 degrees to a minimum final thickness of 0.2mm, which results in a bare area 0.3mm +/- 0.25mm in the vertical direction in your drawing.
Edit: I just spoke with the mechanical engineers and they confirmed what @Mattman944 said: the center of each contact must be within 0.15mm of its calculated position relative to the datums A, B, and C, which is the midplane of the card, instead of position relative to the next contact or some other reference point.
I'm afraid I can't help with the rest of the red box.
