I have a question about a 12 V to 12 V isolated DC-DC converter.
I am trying to connect a Bluetooth adapter to my old Becker radio, but I got some annoying noise when it was connected. It turned out to be a ground loop, so I bought a 12 V to 12 V isolated DC-DC converter (B1212S-1W).
Today I connected it and after I turned the radio on the DC-DC converter just smoked and got super hot, so I guess it's toast now.
I connected it using the following diagram:
I connected GND (pin 1) to the main ground of the car and the Vin (pin 2) to the switched positive on the radio. I then connected -Vo and +Vo to the Bluetooth adapter's ground and positive cables.
I guess I somehow shorted it, but shouldn't the wiring be correct that way?
I also saw this video and in the end he said it should be connected in series (the same as I did).
Sorry for the late reply.
There was only this bluetooth module connected to the converter. I just measured it and on startup (where it draws the most) it only has a max amperage of 20 milliamps, so that shouldn't cause this issue right? After a few seconds it drops to 0 amps on the multimeter.
Edit: Are there any other 12v to 12v isolated dc-dc converters for cars? Because when i search i can only find these things.
Many thanks!
