I am helping a high school student with a physics experiment on internal resistance of a cell. My background is in chemistry, not physics.
Browsing SE for lab design, Measurement of internal resistance of a battery pops up. Now the high school lab cannot generate square waves so I was looking for alternatives.
I understand that in an open circuit, emf is the same as the voltage across the cell. The school does not have a potentiometer. There are videos such as this video at 4:20 that shows an open circuit, with an emf measurement. But wouldn't the cell form a circuit with the multimeter, thereby voiding the set up because the current is non-zero?
Please kindly point out what I am missing, and provide me with tips on how to avoid shorting the circuit and/or the multimeter. Thank you!
okzoomer
  • 175
  • The high school can't generate square waves? Every Arduino can! – Thomas Weller Sep 26 '22 at 15:35
  • @ThomasWeller thanks for the suggestion. I think open cell voltage measurement with a multimeter gives a reasonable level of precision for a high school lab. The linked methods seemed to be manuals for car battery resistance instruments. The cells used in the lab should not require that level of precision. – okzoomer Sep 26 '22 at 22:50
The multimeter does indeed form a circuit with the cell. The multimeter is designed to have a very high resistance, such as 10 mega-ohms, when in voltage mode. So the current is nearly zero - it's nearly an open circuit. Because the current is so small we assume it makes no noticeable difference and call it an open circuit. If you have a \$2V\$ cell and a \$10M\Omega\$ meter, the current is \$0.2\mu A\$.
If the cell's resistance isn't much lower than the multimeter, then you do need to calculate a correction, or use a different kind of measurement. For example, you could measure the voltage with different amounts of current, and then calculate what the voltage would be with zero current (open circuit).
(Likewise, the multimeter is designed to have a very low resistance in current mode - an approximate short circuit)
user253751
  • 11,998
    It might also be useful to discuss measurement techniques and limitations. The 10MΩ is entirely reasonable since the error contribution is much less than the uncertainty due to temperature variation. – MSalters Sep 26 '22 at 11:49
    @okzoomer btw this is exactly the same as with any measurement in chemistry, or indeed anything. Put a thermometer in a liquid and you take energy from it. Add a drop to turn a titration to the other colour and you are *over* the threshold. (Add an indicator and you change the chemistry, at least on some scale). There are no measurements which don't change the system measured: it's just a question of getting the influence to a low enough level to be useable. (For instance you *can't* use a standard DVM to measure the potential across a gold-leaf electroscope). – 2e0byo Sep 26 '22 at 13:37
  • "are no measurements which don't change the system measured" --> unless we use [Heisenberg compensators](https://memory-alpha.fandom.com/wiki/Heisenberg_compensator). ;-) – chux - Reinstate Monica Sep 26 '22 at 15:35
  • thanks I saw the edit. I did advise the student to measure current only with a resistor in the circuit. – okzoomer Sep 26 '22 at 22:27
    @okzoomer If the cell is small you might measure it without a resistor. This measurement is called short circuit current. Most multimeters have a 10-amp current mode which should be adequate for most realistic classroom experiments. The only reason it's usually dangerous is that people try to measure power supplies that can output very large amounts of current. – user253751 Sep 27 '22 at 14:04
You can measure the internal resistance by applying a reasonable load (the definition will vary depending on the cell construction and intended use) and measuring the change in output voltage. Since batteries are not simple ideal voltage sources with fixed resistances in series (as they are sometimes modeled) the voltage drop will not necessarily be proportional to the current drawn, it will change with the time the load is applied (and how long since a load was last applied) and with environmental variables such as temperature. Also, of course, with state of charge of the cell.
If we think of it as a simple resistance in series with and ideal voltage source, then applying a load of R1:
Open circuit voltage is 9.000V. Voltage with 100 ohm load is 8.824V, so a current of 88.24mA drops 0.176V so the internal resistance must be 2.0Ω in this case. As it happens that's the default internal resistance in Circuitlab for a 9V battery.
If the load is relatively light then the voltage change will be small so you need a good resolution meter that will be stable during the measurements.
Spehro Pefhany
  • 376,485
  • 842
  • Most DVMs have an input resistance of 10 Megohms - as Sphero states this is such a light load that the cell is effectively open circuit when just loaded by the meter. – Kevin White Sep 26 '22 at 01:13
  • I may be misunderstanding ... this does not answer my question about how to measure open circuit voltage with a multimeter? Are you saying it grounds the circuit? – okzoomer Sep 26 '22 at 01:27
    @okzoomer: The battery and multimeter form a circuit - I would not say the meter "grounds" the circuit. In Spehro's circuits, I would have completed the circuits with wires, rather than showing Ground symbols, as ground is not relevant here. the term "Ground" is much misused in electronics - the Ground symbol usually just marks the place we want to call "Zero Volts", and has no special properties. – Peter Bennett Sep 26 '22 at 01:51
  • @PeterBennett ok. My question was asking if it's possible to measure the open cell voltage if the multimeter forms a circuit with the cell, presumably with non-zero current flow through. I have since bolded my question. Please feel free to edit it if it's not clear. – okzoomer Sep 26 '22 at 02:07
    Yes, the "ground" in the circuits shown can simply be thought of as a common connection. Circuitlab uses SPICE simulation and it may not be happy if it doesn't see a ground, so my habit is to ground the circuit somewhere. – Spehro Pefhany Sep 26 '22 at 02:19
To add some background clarification to the excellent answers already given. There is a conundrum under this question which bears some explanation.
What we ideally want to do is measure electric potential without drawing ANY current. In practice this is rather difficult. There are physics techniques such as using an electroscope, but these are too impractical for most electronic engineering situations.
So what we do is measure while drawing a very small and known current. That is, we use a meter with a known, very high input, resistance. "High" is of course a relatiuve term; for most multimeters it is 10M ohm, which is chosen to work well enough with general purpose circuits which will use resistances typically in the ohms or kilohms region.
However we should always remain aware of what we are doing, in order to make allowances when working with "high impedance" circuits. This might occasionally be a concern when working with sensitive FET based circuits that (for instance) work with a capacitive transducer, such as an electret microphone. These circuits are designed to have impedances in excess of 100 Mohms or more, and we would not expect them to work properly with our multimeter connected. Indeed the reading obtained might well differ from the voltage in the circuit in normal operation, due to the excessive load presented by it.
For your purposes, you expect the load resistor to be perhaps a few hundred ohms or so. Measuring with a device with 10M input has a negligible effect : yes, we are drawing current, however such a small one that it can be disregarded.
danmcb
  • 6,009
