I was looking at figure 33 of the OP77 datasheet, and the JFET labeled D2 has an odd connection. Based on the way the circuit works that JFET must be a diode right? So why is the JFET connected as it is in the figure?
David
  • 171
  • I thought this was a duplicate (http://electronics.stackexchange.com/questions/16966/transistor-as-low-leakage-diode/) But now I see that question asked about the BJT, while your question asks about the JFET. – The Photon Mar 27 '13 at 20:53
The JFET is acting as a diode. So why not just use a diode? The main reason for using a JFET as a diode is that it has low leakage compared to ordinary diodes.
Kaz
  • 19,838
  • 39
  • 82
It is acting like a diode. Because the circuit in question is an absolute value amplifier it has to handle positive signal excursions differently to how it handles negative signals because basically it's a precision full-wave rectifier.
