I was searching for a TRIAC to be used as part of a pre-charge circuit for large DC link capacitors, and found one (T435T-600FP) that is described as "snubberless". An on-line search did not find anything definitive, although it appears that they may be limited to three quadrant operation. For my application I will just be using the TRIAC with a zero-switching opto-TRIAC on the AC side of a FWB to precharge a 560 uF 350 VDC capacitor through a 100 ohm resistor (56 mSec TC), before closing a relay for operation.
It appears that the TRIAC has a minimum of 5.3 A/ms rating without snubber, and critical rate of rise of ON current of 50 A/us. I thought the snubber was more for dV/dt protection, which is listed as minimum 750 V/us (apparently without snubber). These specs probably are not important for my present application, but I'd like to know more in case I need to use a TRIAC where it may matter - perhaps for inductive loads like solenoids or motors.
Some relevant references:
(edit) A discussion about this, but with two differing opinions:
and
https://www.eevblog.com/forum/beginners/snubberless-triac/
Bottom line seems to be that a snubber is not needed for three quadrant operation, but term may be marketing hype.
