It is easy to implement round robin (A->B->C->A->B->C..) using FSM in VHDL. Is there an alternative to FSM? For some reason, I have a feeling there is a nice and neat implementation without using FSM.
user7586189
  • 161
    It depends if you consider a counter to be an FSM. Which it is, though it may not look like one. –  Sep 08 '22 at 22:10
    Since FSM is "just" an abstract concept, any implementation I can think of is an FSM. What design that stores a state and changes on input conditions would you not call an FSM? – the busybee Sep 09 '22 at 05:54
There are two main goals:
  • your code should be readable
  • your code should synthesize well
If the FSM fulfills both, then it is the way to go.
If your only transitions are A->B->C->A->..., then the implementation is likely three flip flops in a circle. The FSM with an enumerated type resolves nicely to that because the enumeration will use one-hot encoding by default, and the FSM viewer can be used to inspect this, which is also nice if you want to keep your project readable.
Simon Richter
  • 12,031
  • 49
