Can 0 Ω resistors be used as fuses? I can't find any fuses physically small enough to fit on my board that can also take the current we're expecting.
In my application, 58 A is the expected continuous current in situations where the software has accidentally turned on every peripheral. That would be rare, but we don't want the fuse to blow in this situation.
The situation where we do want the fuse to blow would cause hundreds of amps to flow through the fuse.
However, the only fuses I can find that fit on my board are 1206 and rated to 50 A which would lead to many false blows, even when the software hasn't accidentally turned on every peripheral. The next size up for fuses is massive.
Is it possible to use something like a 0 Ω resistor in a 2512 package as a fuse, e.g. something like CR2512AJ/-000EAS which is ≤50 mΩ and has a maximum current of 5A? But at what temperature and current will it break?
I'm surprised that I can't find any ceramic 2512 SMD fuses. It has to be ceramic.
