Is 8.6 amperes per meter, 70 microtesla, 0.70 gauss, 695 milligauss, safe on long time exposure?
I am just worried.
I am just worried.
According to Wikipedia :
“The magnitude of Earth's magnetic field at its surface ranges from 25 to 65 μT (0.25 to 0.65 G)”
https://en.wikipedia.org/wiki/Earth%27s_magnetic_field
So the measurement you have is essentially only the geomagnetic field, the same one we’ve experienced since birth. As to danger from static fields, the American Conference of Governmental Industrial Hygienists (ACGIH) established occupational limits which are quite high compared to your readings:
Whole body: 2 Tesla
Medical device wearers: 500 micro Tesla
Adapted from UoT's rad safety documentation, See Table 1: https://ehs.utoronto.ca/our-services/radiation-safety/emf-safety-program/
So to finalise: you are measuring a magnetic field that is effectively the same as everyone you've ever met has lived in their entire life, and standards bodies agree that our most magnetically sensitive friends can withstand 7 times as much before becoming concerned.
70 microtesla, 0.70 gauss, 695 milligauss.
These values are all the same but in different units.
100 microtesla = 100 uT = 1 gauss
Do we assume this is 50 or 60Hz? if so, 70 uT is below the safety agency of 100 uT for power line frequency for the public and the occupational levels permitted are 10x this level.
This level of exposure is below risk levels for continued public environment Occupational levels permit 10x the 100 uT levels at line frequency.
I found these 2010 safety references
Since MRI's do not use a radioactive source but rather 64 MHz or 128 MHz brief durations of 1.5 to 3 Tesla or 1500 to 3000 Gauss are consider safe for for high contrast brain and body imaging. But the subject must be void of metals containing iron implants.
There is increasing therapeutic interest in using repetitive Functional Magnetic Stimulus rFMS with repeat sessions for healing symptoms from PTSD, anxiety, tinnitus (apparent ringing in ears), clinical depression, & weight loss. The equipment is widespread in therapeutic centers around the world. One global supplier of 2 Tesla ultra-low frequency FMS machines in Slovakia. here.
For rFMS, at an extremely high level of 2 Tesla at ultra-low frequencies (ULF) stimulates the action potential in muscles but not at RF frequencies. Unlike Electrical stimulus or ECT, it is non-invasive and applied with coils near the body and only applied by experienced health care professionals.
I have done some research in this area. You might be interested in the spectral info I computed on an old image I created below.
