I want to do something similar to this question: PCB "Touch" Button
However there the PCB was not described that much. I have a design where each 'finger' is 1mm apart.
And I'm not sure should I make the finger contats larger to allow better contact with the skin, or rather smaller but more frequent to go over smaller distance of the skin.
My gut feeling the increased contact path with larger fingers will not overcome the disadvatange of covering longer length through the skin. So smaller more frequent fingers should be better?
Anton Krug
  • 135
    Eventually dirt, grease, oxidation and whatever will add to the surface and it will stop functioning. That is probably why all cheap keypads you find in the world adds a mechanical barrier that adds some form of protection and consistent connection. – Dejvid_no1 Sep 03 '22 at 21:35
  • Mechanical barrier, you mean soft pad with carbon so then the finger is pressing the button from the outside, while inside has the carbon making the connection even easier? I'm willing to clean this button once a week, if the button will be reliable within one week then I'm fine with this flawed design. – Anton Krug Sep 03 '22 at 22:26
    No problem. But hey I found metal domes on Digi-Key! Search for 5133TR for example. Hope that helps. :) – Dejvid_no1 Sep 04 '22 at 16:04
    Thanks, I have these stock in person, but wanted to practice this comb fingers style just to do it for sake of doing and in process educate myself on why exactly they are not videly used anymore. – Anton Krug Sep 07 '22 at 12:03
For resistance it depends on pressure, conductor and moisture of skin over the surface area. There may be a preference you have for pressure which affects contact area, so you may experiment with a DMM and record your range of values for dry and oil skin vs pressure for a fixed probe contact area. Don't use the sharp tips which will conduct thru the subcutaneous layers which have lower ionic resistance. These experiments may help. But essentially more trace width and area of contact will reduce resistance of skin, while closing the gap for insulation and contamination. The untinned copper will oxidize so you may choose to DIY etech or use organic gold plating or tinplate or hot air solder leveled HASL.
The reference circuit will work with a wide range of pressures and skin moisture levels. But for one person to use, less variability. enter image description here
There are endless options for patterns but you want the finger capacitance to be much large than the trace capacitance. A 100 pF is nominal value for a finger tip ( from the HBM spec) unless you push hard, then x10. Sensitivity is up to you to define. Impedance is also up to you when you choose the frequency.
If you make the circuit signal to idle ratio 4:1 minimum with 1:1 hysteresis then you may want to define 100 pF for the finger tip and idle capacitance of 25 pF between traces. Geometry makes a difference and length of path for total surface area of finger to conductors.
It makes perfect sense to experiment and measure with a relaxation oscillator different pad designs for input capacitance and use a 1M feedback resistor with a good solder mask for insulation.
Saturn PCB toolkit V8.21.exe can tell you this in pF /cm for any coplanar gap and track width with a ground plane or not with some imagination.
You can make it a round target or two coplanar spirals or interleaved forks.
For contamination control, you can use a solder mask over the whole surface.
Carbon keypad buttons use a resistance which degrades over time. Your finger capacitance depends slightly on moisture but more on pressure and is very sensitive at higher frequencies used across the pads but no RF is need)
I have seen some students use pads as a DJ sound control and use rotary finger patterns to control volume or linear control for crossover and not just ON/OFF.
So use your imagination to define a spec, simulate it, make it, test it and measure it. Then repeat until perfect. (Or copy someone else's recipe)
  • Not sure if I can do it as a capactive touch. I have written a software implementation of a capacitive touch sensing but that requires the MCU to be powered on to do the sensing as this MCU doesn't have any HW support for capacitive touch. While with resistive aproach the device is in sleep/powerdown and the resistive touch triggers for it a external IRQ to wake up. With the solder mask, I have whole rectangle open while paste mask applied so the traces are tinned. What exactly you meant? And how does it control contamination? – Anton Krug Sep 03 '22 at 22:32
    Surface contamination varies greatly while capacitance does not. If you can handle the power consumption of an oscillator running at say 20kHz, then use the resistive method with larger gaps, smaller tracks. All it takes is 2 inverters 2 large resistors (10M, 10k) and 1 small cap – Tony Stewart EE75 Sep 03 '22 at 22:41
  • You mean to get a hex inverter for example, feeding it into each other to start oscilating and then use the capacitance of the finger to affect it? – Anton Krug Sep 03 '22 at 23:49
    on the other hand complexity is increased to compare targets for moist surfaces, so that's another form of contamination but high resistance until dust accumulates.. So it depends on how reliable you want your sensor. Like consumer goods with glass surfaces and wipe detect suppression software or any old switch for Wake up and auto sleep. A FET or CMOS will also need ESD protection. If you used stray hum and a Darlington , you could detect stray signals with touch or even a handwave on a fixed installation. – Tony Stewart EE75 Sep 04 '22 at 01:12
    Your pattern could also be a checker board with pads in each square all fed by bottom trace vias.. With 2 detectors close together and swipe left or right and detect the sequence for two different functions – Tony Stewart EE75 Sep 04 '22 at 01:17
  • Swipe left and right are not needed, the device is one-off (no volume) for personal use (by myself) and I'm willing to clean it with IPA once a week. Checker board you mean the 'white' squares would be sense and 'black' would be vcc? with tiny gaps between the checkers? Would that improve reliability/sensitivity, or just looks? I was thinking to use BSS138 as transistor, would ESD9L5.0ST5G diode be ok? – Anton Krug Sep 04 '22 at 02:40
    That will work fine and you can measure your range of dry to moist finger resistances with your comb like surface area to determine the Rgs value. But do add a series R and TVS protection or something for ESD. A cap also may reduce EMI if present. – Tony Stewart EE75 Sep 04 '22 at 12:14
  • The cap accross the D1? Would 100pF do? – Anton Krug Sep 04 '22 at 12:58
    100 pF * 10k = 1 us, while up to 1 ms or 10k*100 nF would do more without switch delay being noticed – Tony Stewart EE75 Sep 04 '22 at 13:31
    I will go with 100nF, thank you for all the advice – Anton Krug Sep 04 '22 at 16:22
