I am trying to build a DIY Bluetooth speaker using a 18650 battery cell, a TC4056A battery charger board, an XY-016 that raises the voltage to 6.5 V, a 2200 μF capacitor, and a CSR8645 board. I am using two speakers rated at 5W, 4 Ω. The components are very similar to the ones used in the aukits DIY kit, an older version.
The problem I am having is that at maximum volume, on some more punchier songs, the assembly shuts off and the TC4056A board outputs only 1.5 V. I have to shut it off and turn it back on, then it goes back to normal. I also have a 3 mm LED in parallel with the output of the TC4056A board and when the bass kicks, it dims following the rhythm.
Many people have built a similar speaker and didn’t have any issues so I am expecting for this configuration to be OK. Do you have any suggestions?
