Summary: what are the risks / is it advisable to run rechargeable bike lights at the same time as they're charging from an external power source?
There are plenty of bright rechargeable bike lights these days. They're great, but in my experience they tend to come with modest li-po or 18650 batteries, which, after a year or so, no longer run for more than an hour before requiring recharging. That means they run out during a long ride. Also, if you've been out riding with family, it's quite a drag to have to dismount front & back lights from several bikes and find micro-USB chargers for them all indoors, then remember to remount them all on the bikes before the next ride.
I am wondering about connecting a bike's front and back rechargeable lights via their micro-USB ports to a 10,000 mAH 'power bank' sitting in a little frame-mounted bag, and charging them WHILE they're lit. I am hoping this could increase run times and that it would be easier to take only the power bank inside occasionally for topping up.
However I am wondering if anyone is familiar enough with the commonly used bike light circuit designs to be able to comment on what might happen over the long (or short term) with a setup like this.
Most importantly: will the bike lights' batteries likely be damaged? Is there a high chance of fire? Anything else to watch out for?
Maybe most bike light batteries don't charge while the light are on, and will end up just switching off when their onboard battery runs out? If the bike light battery is full, will the load from the light itself be insufficient to prevent the power bank from going to 'sleep'? Either of these situations would make the whole setup pointless, albeit not a danger.
