I am transitioning from Arduino to STM32 development. I just purchased an STM32F401CCU6 board and I cannot get it recognized by my computer. I am running Ubuntu 22.04. I have tried searching everywhere but there is such poor documentation and support for working with ST (compared to Arduino and Espressif). My board has a USB C port on it but after watching countless videos and reading numerous forums, I've come to know that normally we use external programmers for development with these STM boards. I also have an external programmer (FTDI) if that's how it is supposed to be done.
I have showed the output of my 'dmesg' window, clearly showing the device recognized on a hardware level. But it is not recognized anywhere else. I tried finding it as a COM port via Arduino but did not find any available ports. I tried programs like CoolTerm and Putty but I could not see the port appear there either. I tried 'ls /dev/tty*' but did not find the device anywhere.
[282059.230618] usb 3-1: new full-speed USB device number 51 using xhci_hcd
[282059.380114] usb 3-1: New USB device found, idVendor=0483, idProduct=df11, bcdDevice=22.00
[282059.380123] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[282059.380126] usb 3-1: Product: STM32  BOOTLOADER
[282059.380129] usb 3-1: Manufacturer: STMicroelectronics
[282059.380131] usb 3-1: SerialNumber: 359B33733237
I used the push buttons on the board to put it in DFU mode (no idea what that is) and I can confirm it worked because the user LED went off. But I still do not see it appear anywhere on my system. I also have a Nucleo F401RE and I never had to do anything extra to get it recognized by the same system (it was plug and play).
When I try to 'run' a program via CubeIDE, it says "No ST-LINK detected!". I have been stuck for days on this issue and I cannot figure out what needs to be done to flash a program onto it. It is just paperweight (a very inefficient one) at this point.
I tried using CubeProgrammer as well but could not establish a connection through either option - USB, UART nor ST-LINK. USB and UART require COM ports so they both failed. ST-LINK also failed to detect anything.
Any insights and guidance shall be greatly appreciated.
Harit
  • 73
    *Which* board?? Many of the dev boards have ST-Links built in, but without knowing which board, it's tough to develop any insight – Scott Seidman Aug 15 '22 at 14:09
  • Appreciate your response. I don't know the model number of the board, but the one in this image is the exact one that I have: https://www.mischianti.org/wp-content/uploads/2022/02/STM32-STM32F4-STM32F401-STM32F401CCU6-pinout-low-resolution-1024x623.jpg – Harit Aug 15 '22 at 14:19
    Beginners shouldn't be programming through bootloaders anyway IMO. That way you end up learning about a lot of irrelevant things like how some specific bootloader works. Instead you should flash it over SWD (in case of Cortex M) using an in-circuit debugger. And that way your PC doesn't need to detect the board because why would it. Just power it up and leave it to the in-circuit debugger. – Lundin Aug 16 '22 at 06:54
There are issues with the 'Black Pill' (25MHz HS crystal) design and DFU. Recommendation from ST:
Note: Due to HSI deviation and since HSI is used to detect HSE value, the user must use low frequency rather than high frequency HSE crystal values (low frequency values are better detected due to larger error margin). For example, it is better to use 8 MHz instead of 25 MHz
Apparently you can physically heat the chip to shift HSI clock frequency and help it properly detect the HSE crystal frequency at power-up (it's looking to detect even MHz values), but why bother?
I suggest using an STlink (V2, V3, or clone, any of which just works). Debugging capability is really important anyway.
Spehro Pefhany
  • 376,485
  • 842
  • FWIW, there is at least one version of STM32CubeProgrammer (Windows)that doesn't seem to work with DFU on Black Pill, even when the device is showing up properly in USBview as an STM32 device in DFU mode. V2.5.0 works and V2.11 works. Also, the bootloader does not seem to like USB hubs. – Spehro Pefhany Aug 18 '22 at 17:31
Looks like a WeAct BlackPill -- https://docs.zephyrproject.org/2.6.0/boards/arm/blackpill_f401ce/doc/index.html
It has a boot loader, as do all the stm ARM cortexes (I believe), but no on-board programmer. It does allow programming with a programmer, though -- you would need to pick up an ST-Link clone.
I think the page I reference above will give you enough direction to use your device.
"DFU" is Device Firmware Update -- i.e., programming the device using the bootloader.
UPDATE: It looks like there may be issues using the Cube environment to program via DFU (https://community.st.com/s/question/0D53W00000euMKeSAM/stm32cubeprogrammer-doesnt-support-dfu-files) I can't confirm.
https://youtu.be/b1123kz_3MM has instructions for using Cube to program these. It involves finding and installing the STM32 core for Arduino, and doing some stuff in the Arduino Board Manager.
Scott Seidman
  • 29,274
  • 44
  • 109
  • A link is not an answer ... – brhans Aug 15 '22 at 14:33
  • Multiple links - still not an answer. – brhans Aug 15 '22 at 15:13
    @Brhans I'm not sure I agree -- I think there is valuable info in there, but I'll consider deleting when a better answer comes along. In the meantime, consider a downvote, because this one won't get better. – Scott Seidman Aug 15 '22 at 15:53
  • I don't doubt there's valuable info on he other end of those links, but without them your answer boils down to not a lot more than "it has a bootloader, 'DFU' is that bootloader, you need an ST-Link to program without using the bootloader". ¯\_(ツ)_/¯ – brhans Aug 15 '22 at 16:03
    ... thus answering at least part of the question. "You can install a core in the Arduino environment to allow Cube to program the device" and pointing to specific instructions of how to do that is another part. – Scott Seidman Aug 15 '22 at 16:05
  • @ScottSeidman You were on point! It is indeed a WeAct BlackPill board. I managed to download and configure dfu-util, which allowed me to flash the Blink sketch. I guess I would need an ST-Link to program this without the DFU hassle. I think it's ridiculous to have a USB port right there and not be able to use it to program the board (using CubeIDE). I definitely need to use it with CubeIDE so I will get an ST-Link. Thanks for your valuable insights! – Harit Aug 16 '22 at 07:32
  • @ScottSeidman I have a nucleo board (f401re) as well with an embedded ST-Link and a bunch of jumpers and headers. Is there any way I can wire up this BlackPill through that ST-link to program it like I program the nucleo board? Thanks in advance. – Harit Aug 16 '22 at 10:16
    Yes, perhaps you can use the Nucleo's ST-LINK. See section 6.2.4 "Using ST-LINK/V2-1 to program and debug an external STM32 application" in the [Nucleo-64 User Manual](https://www.st.com/resource/en/user_manual/um1724-stm32-nucleo64-boards-mb1136-stmicroelectronics.pdf). – kkrambo Aug 16 '22 at 13:11
  • @kkrambo Thanks for the link! Is there any other stuff that needs to be done? When I googled the procedure, I came across this tutorial where the guy desolders a bunch of 0 ohm resisters on the underside of the nucleo board to break the connection with the board's MCU. It doesn't say anything like that in the user manual. Have you tried doing it before? – Harit Aug 17 '22 at 07:27
    @HaritKrishan Cross reference the tutorial with section 6.9 "Solder Bridges" in the User Manual. That should help you understand and work out what is appropriate for your situation. I have not used a Nucleo-64 board like this myself but at least SB12, SB13, and SB14 seem relevant so you should investigate further. – kkrambo Aug 17 '22 at 14:35
  • @ScottSeidman I obtained an ST-Link V2 for programming the board via SWD. I want to understand the bootloader stuff a little better. So at the moment, there is a custom bootloader on it (from WeAct / Zephyr) as you clarified. What is the correct bootloader to have if I want to program it through CubeIDE? Or does the bootloader not matter if I am using ST-Link? Will I be able to receive data via UART (the type C port) with this custom bootloader? Thanks in advance. – Harit Aug 23 '22 at 12:40
I figured out how to start 'using' the board. As Scott Seidman pointed out, it was indeed loaded with a custom bootloader from WeAct/Zephyr. Once I connected it via ST-Link using the SWD pins, I was able to connect it to CubeIDE and program it normally, like a Nucleo Board. I first had to perform an upgrade (which CubeIDE automatically prompts you to do) by putting the board in DFU mode. Depending on which board you have, it is a particular combination of the on-board buttons or switches.
Voltage Spike
  • 75,799
  • 80
  • 208
Harit
  • 73
