The Circuit
The rectifier comes from TI's TIDU030: Precision Full-Wave Rectifier, Dual-Supply application note.
My "benchmark" used as a baseline for evaluation is as shown below, powered from +12V/-12V, with a 4u6/50V tantalum across U2:4-U2:8.
R2=R3=R4, and the rectifier has gain of +/-1. The architecture is nice as it keeps both op-amps operating closed-loop, without saturation.
Anytime U1's output polarity changes, it has to slew two diode drops. This introduces artifacts near zero. The duration of those artifacts grows as the amplitude of the AC signal on the input decreases. This is mentioned and measured in the application note. It's one of the drawbacks of this architecture.
The transition waveforms I've measured for a 1kHz square wave of 1Vpp, 100mVpp and 10mVpp amplitude, are:
Transition waveforms as measured
Note that the lowest amplitude waveform has a 10us/div time base.
The simulated waveforms from the app note look quite similar:
Waveforms of prolonged transitions as the input signal amplitude decreases
As a partial fix, D1 and D2 could be RF Schottky types with lower forward voltage drop, decreasing the slewing U1 has to do on zero crossover.
The rectified 1Vpp sine wave:
Rectified 1kHz 1Vpp sine wave as measured
The character of aberrations in the rectified signal is very similar to that shown in the app note for 1kHz 50mVpp rectified output:
1kHz 50mVpp rectified output measured in the app note
Note the time scale: The shape/slew rate of the aberrations is same in both circuits, in spite of the app note using quite a bit faster op-amp.
What both circuits share in common is the 1N4148 diode.
It seems that this circuit under-utilizes the op-amp.
I had to use averaging to obtain the traces, just as the authors of the app-note had to: otherwise, modern scopes without preamps are too noisy for such pretty pictures.
This is to assure anyone trying to reproduce the plots: without averaging they look like a big noisy mess, especially at the 20mV/div and 5mV/div.
The Question
Is there some way to fundamentally mitigate the effects of forward voltage drop across the diodes (making it effectively "very small"), so that the transition times would be improved, essentially turning the diodes into ideal diodes?
I'm looking for improvements that don't change the op-amp type. Those improvements will also improve performance with better op-amps, by lowering the slew-rate requirements of the op-amp to be more in line with what the signal itself requires, rather than diode slewing.
I've been experimenting with adding synthetic voltage sources to "undo" the voltage drop on the diodes, but perhaps there are other known approaches to such problems.
I assume that there may well be several ways to do it, e.g. depending on the supply vs. signal voltage span, etc.
    As in, without using a higher GBW amp? – Tim Williams Aug 12 '22 at 21:44
  • Yup. Some of the amp's slew rate is used up by having to "jump across the river" each time the polarity changes. The only way I see to make this topology work better is to have ideal diodes - that's where the problem lies. Making the diodes behave in an ideal fashion requires modifications of course. This problem is especially egregious on slow op-amps. An LM741 ideal rectifier works acceptably at mains frequencies, and quickly runs out of steam soon thereafter. I have added ideal diodes using fast op-amps to the 741-based circuit and it worked quite acceptably at 1kHz. – Kuba hasn't forgotten Monica Aug 12 '22 at 23:19
  • Just for sake of completeness -- in the benchmark circuit, did you try different R and C values (and in particular, R+C instead of just C across the one amp)? Note that diode performance is relative to the resistors around them, and diodes tend to be quite low impedance devices when you need them to move fast. 1N4148 is pretty good considering, and BAS70 might be a schottky to try. – Tim Williams Aug 13 '22 at 00:46
  • @TimWilliams Good idea about a snubber instead of plain capacitor. I'll also see what happens when the resistors are smaller, although I don't expect miracles since TL072 doesn't really have all that much gain to go around under heavier load. On the other hand, the behavior to correct happens around 0V output, when the output currents are lowest. – Kuba hasn't forgotten Monica Aug 13 '22 at 00:49
  • What accuracy do you need (esp. around the lowest AC input voltages) ? Fundamentally in this circuit, the diodes are switches and need 0.7 V swing to bias them. If you reduce this (e.g. with V sources), you will degrade accuracy because of leakage in the switches. – jp314 Aug 13 '22 at 00:55
  • Oh also, is this 100% for TL072 exclusively, or are other types allowed (but of comparable GBW given the earlier stipulation)? – Tim Williams Aug 13 '22 at 01:31
  • Also also, compare with this circuit? I use it more often, though I forget how it compares with others. https://i.stack.imgur.com/AGiIc.png – Tim Williams Aug 13 '22 at 01:44
  • I'm thinking of just sticking to one particular type. I'm sure just throwing a much faster op-amp there would improve things a lot. – Kuba hasn't forgotten Monica Aug 13 '22 at 02:27
  • https://dspace.vutbr.cz/bitstream/handle/11012/57016/10_03_437_445.pdf?sequence=1&isAllowed=y **A Novel Current-Mode Full-Wave Rectifier Based on One CDTA and Two Diodes** addresses fast switching and small signals using a fast *diamond transistor* arrangement. Might be of interest. – glen_geek Aug 13 '22 at 13:25
  • @glen_geek That's an excellent find. It will work with older OTAs as well, I'm sure, lowering the cost. I'm still on the lookout for "easy" improvements to the basic circuit, so that the scores of beginners who play with very basic op-amps would get reasonable performance if they actually need a precision rectifier for more than rudimentary study. – Kuba hasn't forgotten Monica Aug 14 '22 at 15:27
I have thought of these methods. You need to experiment to see if any of these is good enough for you.
  • Use a comparator and switch to switch a signal depending on whether it is negative or positive. There are a few signals to switch that may achieve the purpose, for example switching between the normal and inverted inputs, or switching one of them on or off with twice the amplitude. There are chips like the AD8037 with comparators and an op amp designed for this purpose. Read its datasheet for more about this method. Figure from datasheet.
  • Convert to digital with an ADC, rectify digitally, and convert back.
  • You can make a half-wave rectifier by using a CMOS rail to rail output opamp whose negative power rail is connected to ground. Then sum with input to get a full-wave rectifier. CMOS opamps don't suffer from saturation, so they may recover faster. But I don't know whether this method really works. If any of you tried this, please leave a comment.
  • You can switch an opamp on or off with the comparator method if the opamp supports gain setting or being switched off. The late Jim Williams used the LT1228 to measure the settling time of 20-bit DACs, as described in Application Note 120.
  • In your original circuit, the problem is that the opamp slews too slowly when its output is near ground. When an opamp doesn't have enough output capabilities, maybe a buffer can help. There is an inexpensive buffer that has high slew rate and gain bandwidth product, and better yet has high gain when output is around ground. It is the CMOS digital inverter. Unbuffered ones like the 74HCU04 have only one stage, making its gain fall off with one pole, which means they are about as easy to compensate as opamps. But be aware that these have high output impedance in the linear region, so add a buffer at the output of the entire precision rectifier if there is a large load. This usage of CMOS inverters is described in The Art of Electronics: The x Chapters.
  • Wire up a simple opamp follower. Connect a resistor from its output to ground. Depending on input polarity, current through this resistor is supplied by the either VCC or VEE of the opamp. That means VCC and VEE are half-wave rectified versions of the input if you regard them as current outputs. Make sure the supply pin is connected to a low impedance like the emitter of a transistor to prevent nasty problems.
Ideal diode controllers switch on FETs, which requires slewing much more than 0.7V usually.
For this to work fast, ultimately you again need some kind of fast-slewing op-amp.
You might aswell replace the op-amps in the original circuit with faster types to solve the same problem. Schottky diodes also help if you're after smoother crossover.
tobalt
  • 18,646
  • 73
Using opamps (which are loop compensated) and diodes to switch loops will always have some type of unnecessary delay as some signal transitions through 1 or 2 diode drops.
Instead, use 2 opamps: One as a buffer (+1); the other as an inverter (-1). Each opamp will remain linear and in closed loop. Use a comparator (with small hysteresis ?) to select the +1 or -1 signals depending on the polarity of the -1 output. Be careful that the BW of the +1 will be higher than the -1; it might need some adjustment.
jp314
  • 18,395
  • The +1/-1 switched method works very well and takes just one op-amp, a switch, and a comparator. I'm aware of many circuits that are not much more complex than the one presented, and work somewhat better - I was asking about that circuit specifically, otherwise this question would be super broad. – Kuba hasn't forgotten Monica Aug 15 '22 at 16:08
Effects of Diode Type
The diode type does affect the results.
There are other tweaks to be made, and I'll be editing more results into the answer as I get more measurements done.
1N4148
This is a small-signal switching silicon diode, and is the benchmark.
1kHz square wave transition transient
Traces for 1.0Vpp, 0.9, ..., 0.1, 0.09, 0.08, 0.07, 0.06, and 0.05Vpp.
1N5711
This is an RF microwave rectifier Schottky diode.
1kHz sine and triangle wave transients
3BX81B B-E junction
This is the base-emitter junction of a Germanium NPN transistor.
It is interesting that the transition delay is getting shorter with decreased peak-to-peak voltage.
These junctions are much leakier, though, and introduce significant distortions, including 20% amplitude error:
