The following is a sata3 data cable picture taken from wikipedia
There are 4 wires for each differential pair, and I guess the two silver-colored cables are grounds, and the two bronze-colored cables are differential pairs.
My question is, what's the benefit of using two ground cables instead of one?
Thanks!
bruin
  • 357
Your picture actually shows four ground wires (two on each side of each of the signal pairs). On the SATA connector, the middle two wires are connected to a single pin, so the connector has three ground pins.
The reason for these four wires is complex (mostly to do with crosstalk); it is well explained here: Why do cables have multiple grounds?
Paul
  • 294
  • Thanks @Paul. It seems that two main purposes were mentioned in that thread, i.e., to alleviate both impedance mismatching (causing reflection) and magnetic field overlap (causing crosstalk). – bruin Aug 11 '22 at 01:30
  • You are right, although mismatching could also have been solved in other ways. – Paul Aug 11 '22 at 12:30
