I recently read an article on EETimes, discussing superconducting power lines to increase transmission efficiency by 5-10% due to nearly zero ohmic resistance. They state that normal power lines
provide protection against surges and lightning
Let’s assume the lightning hits a superconducting power line.
What would happen?
  • Would the energy be „trapped“ in magnetic fields?
  • Would it fry every attached device/transformer on its way?
  • Could this be a way of „harvesting“ electricity?
  • Would simply nothing happen?
JRE
  • 67,678
  • 179
Jonas
  • 107
Practical superconducting cables typically have a (normal) conducting material around or between the superconducting elements, so an impulse that exceeded the critical current density would cause the cable to go normal in near that spot, probably damaging the cable and arcing, requiring repairs to patch the gap with power removed.
Images from
Hu, D., Mi, T. Z., He, Y., & Li, Z. Y. (2017). Experimental Investigation of the Influence of an Encapsulation Layer on the Lightning Current Characteristics of YBCO Tapes. Journal of Superconductivity and Novel Magnetism, 30(6), 1413–1418. doi:10.1007/s10948-017-3990-z
Spehro Pefhany
  • 376,485
  • 842
Superconducting cables dissipate energy when you try to change the current going through them.
If the current spike is not enough to quench the superconducting state, the energy would spread through the grid as surge voltage same as in normal distribution.
But a quench could very well happen, turning the line either into an insulator (YBCO or BSSCO) or a metal (Niobium based materials). This would dissipate the strike energy in a much smaller area, likely incurring structural damage and threatening a failure of the cable, at least until it cools back down.
Therefore, I suppose superconducting lines would need protection much like ESD protection on PCB level. This would limit the voltage over the superconductor to a small level, and limit the current rise rate and consequently energy dissipation. The energy would instead dump in the shunt elements (here depicted as Zener devices):
tobalt
  • 18,646
  • 73
