I just bought a well-made mat that says surface resistivity is 107 ~ 109 Ω.
The multimeters on the market test up to like 20 MΩ.
If I buy a multimeter to test it:
  1. If it displays infinite, I won’t know if it’s just because it’s between 20 MΩ and 1 GΩ, or that it’s truly infinite;
  2. If it displays 20 MΩ, I won’t know if it’s actually 20 MΩ, or else if its between 20 MΩ and 1 GΩ, or else it’s infinite.
(I am very new to this and have not used a multimeter before so please pardon my noob questions.)
How do I test that it actually is working as intended (resistance not so high as to fail to protect the computer parts on it from ESD, and not so low as to fail to protect the human from electric shocks)?
Additional information: It says surface resistivity 107 ~ 109, grounding cord resistivity 105. Should I test these parts separately or connected together?
ocrdu
  • 8,705
  • 30
  • 42
Egoless
  • 67
    Buy an ESD mat tester... Specificaly designed for the job. I've used them myself to prove out anit-static floor coverings. They aren't cheap, but a quick search shows what options are avalible from your prefered suppliers (such as RS, Farnell etc) – Puffafish Jul 29 '22 at 06:34
  • @Puffafish thanks for the info. Although I had a look at your recommendations they’re priced 400+ pounds… I am very torn on this, on the one hand i don’t want to fry my computer and have to spend more as a result, on the other hand i’m just doing some repasting for my own machine, not opening a repair shop and stuff. Expensive professional gear doesn’t seem right for me. so not sure what I should do – Egoless Jul 29 '22 at 07:08
  • The other brand is 800 dollars – Egoless Jul 29 '22 at 07:09
    you've asked how to test it. I question why you need to test a mat for hobbiest use. Assuming it was from a reputable supplier, I personally wouldn't bother testing it. You can often get away with no ESD protection for hobby type things, yes it harms perfromce and reduces life, but that doesn't stop many people doing it that way and having no issues for years. So if you're using the mat properly, I'd say testing it is not worth the cost. – Puffafish Jul 29 '22 at 07:15
    If you bought the mat from a reputable vendor and it has documentation, and it's for home use, I personally would not feel a need to test it independently. Caution is never a bad idea, but... – TypeIA Jul 29 '22 at 07:16
  • Okay thanks guys…I’ll contemplate this a bit – Egoless Jul 29 '22 at 07:39
    If you don't need expensive professional gear, why did you buy expensive professional gear just for your own computer then? There's a lot of ways to fry your computer which the ESD mat won't prevent, and ESD is normally not a huge issue. – Justme Jul 29 '22 at 08:15
    Respectfully this makes no sense... do you test all the rails on your PSU? Do you test your mains voltage for spikes and so on? All these can also fry your computer. If you are not being particularly reckless with ESD (i.e. rubbing your feet on carpet in extremely dry weather), you should be fine.. You can also discharge yourself in relation to the computer by touching its ground (with a series resistor if you want to be extra careful). – Wesley Lee Jul 29 '22 at 08:53
This can be tested with a cheap multimeter, rather accurately even. Multimeters have a rather well defined input impedance when measuring voltages, often either 1 MOhm or 10 MOhm.
So you can set up a voltage divider with the mat like below and estimate its resistance.
$$R_{mat}=R_{in}(\frac{V_{src}}{V_{meas}}-1)$$
If you can't find any info on \$R_{in}\$ of your meter, then put a 100 kOhm resistor in parallel to your meter and use that as \$R_{in}\$.
You can also use a battery or whatever as the voltage source. If the mat is fully insulating, you would read no change in the voltage if the voltage source is present or not.
tobalt
  • 18,646
  • 73
Building an answer from the comments:
You want to test your ESD mat. To do this properly you need to buy an ESD mat tester. They are not cheap (GBP, EUR or USD are all 400plus) but are designed for the job. I've used them myself to prove out an anit-static floor covering during building work. They aren't cheap, but a quick search shows what options are avalible from your prefered suppliers (such as RS, Farnell etc). They do the job and are worth it when relying on it for production and you're spending tens/hunderards of thousands on building work. You may be able to rent one, but I have no idea how easy that will be in you locality.
But you've asked how to test it. I question why you need to test a mat for hobbiest use. Assuming the mat was from a reputable supplier are you're using it properly (wrist straps, proper earthing connections), I personally wouldn't bother testing it. You can often get away with no ESD protection for hobby type things, yes it harms perfromce and reduces life, but that doesn't stop many people not bothering with ESD protetion and building their gaming PC and having no issues for years. So if you're using the mat properly, I'd say testing it is not worth the cost. If you'd bought a cheap thing that claimed to be an ESD mat but you weren't sure, then test it, but it would have been cheaper to buy a proper mat to start with. If you happen to have a tester avalible, then go for it. But as it is, congratulate yourself for doing more than many and relax.
It is good to see you are thinking about it, but is it worth the price? I'd say no, trust your supplier (or change supplier to one you can trust).
Puffafish
  • 3,893
  • It’s not a project computer is the thing. It’s my everyday machine, unlike other hobbyists… if I fry it, I’ll have to buy a new one, and that’s much more expensive than the ESD tester. It is a gamble on me getting away with not testing my ESD protection. Anyway I don’t think i’m buying a professional ESD meter. Kind of just looking for some cheap one-off solution – Egoless Jul 29 '22 at 07:36
  • I think you’re right for the most part but I want to leave this open for a bit in hope that there are outliers with cheap solutions. If nothing i’ll mark your answer as accepted. (Please have an upvote for now) – Egoless Jul 29 '22 at 07:45
    @Egoless But many people are using their computers daily without an ESD mat. What do you do that would require the use of an ESD mat in your daily computer use? – Justme Jul 29 '22 at 09:50
  • @Justme just having to repaste it – Egoless Jul 29 '22 at 16:17
  • @Egoless You don't need an ESD mat when reapplying thermal paste and reseating the heat sink. The motherboard is held within an equipotential metal case and if you touch the metal case you are at same potential with the whole motherboard. – Justme Jul 29 '22 at 16:54
  • @Justme it’s a laptop, a lot of stuff needs to be unplugged and removed to get to the heat sink – Egoless Jul 30 '22 at 07:43
The computer's enclosure is a Faraday cage and works way better at protecting the parts inside than any ESD mat would. Keep the computer assembled and you won't have to worry about any of it.
If you're servicing the computer, then you don't need a mat either.
  1. Have an anti-static wrist strap with a cord with a crocodile clamp at the end. You'd clamp it to the case of the computer.
  2. Only place computer parts on the metal parts of the chassis while doing the servicing.
I presume that normally you're not swapping out motherboards, but maybe addding RAM or storage. For such occasional use, an antistatic mat is unnecessary, and a wrist strap will offer sensible protection to the parts from being touched by you. No other protection is necessary. A mat without a wrist strap is just about useless.
I've been messing about with my PCs for almost 4 decades and I've never used a an ESD mat, and I had no failures that could be reasonably attributed to ESD. I keep one hand or a forearm resting on the chassis, and that's enough to dissipate any charges my feet or my bum would be accumulating from rubbing the floor/chair. If I feel too lazy to pay attention to my arm posture, or if I'm doing stuff with sensitive T&M gear, then I put on a wrist strap and keep it connected to the rack or the chassis. There are some expensive components in RF test gear that are extremely ESD sensitive and can't include ESD protection elements while retaining their primary function (e.g. RF mixers).
Everyday PC stuff isn't even nearly in the same category, and every semiconductor component on the boards in a PC has individual ESD protection on its pins. The subassemblies thus have redundant ESD current sinks on most circuits. All you need then is not to have your body at a potential far above or below the chassis - and the wrist strap does that admirably.
  • Thank you for taking the time to write the answer. The setup is a mat and a strap connected to the mat. The computer is a laptop so the casing isn’t the same as a desktop case (significantly less metal portions) so I’m not really sure it provides the same level of grounding effect. Anyway the info you’ve provided is helpful and I appreciate it. – Egoless Jul 30 '22 at 07:41
