Preamp (9VDC): 6 capacitors (4 MMKO box film caps and 2 CAPAR axial 4.7uF 50v electrolytic caps), 1 3-pin junction transistor (M2N5458), 2 unknown transformers, 5 resistors. See attached image.
Problem: The volume when plugged in has reduced over the years to where I can barely hear it when plugged in at full volume. I can't find any OEM preamp replacement (only cheap solid-state knockoffs) so, a repair is in order.
Proposed Solution: The Ovation rep said it most likely needs a cap job because they degrade over time. An electrical engineer friend said doubtful the film caps are bad and to just replace the output jack (done); 2 electrolytic caps and the 1 transistor; "no need to check them to see if they are good because they need replacing anyway due to their old age. Then, call me if that doesn't work."
Parts:
A. Capacitors: I found two Nichicon capacitors (TVX1H4R7MAA) so, it looks that replacement is resolved unless anyone here spots a problem with my choice.
B. Transistor: The only company that still makes the 2N5458 is Central Semiconductors. I've never heard of them but I'm told they're out of India and make decent stuff which I assume is true because Mouser and some other big dealers carry that brand. However, I still like buying made in USA, Japan, or German whenever I can so, buying the Central makes me a little nervous. The main cross is 5457. I found a Vishay-Siliconix 2N5457 which I know to be a "process 55" transistor like the 5458. And, I also found a Motorola 2N5640 which is supposedly is a cross according to the link below: https://www.componentsinfo.com/2n5458-transistor-pinout/
But I can't confirm if it's a "process 55" transistor, which I'm told is important.
Question:
Would you buy the exact match 5458 made by Central or the cross 5457 made by Vishay-Siliconix or the Motorola cross 2N5640 (assuming the link above is correct) even though I'm unable to confirm if the 2N5640 is a process 55 transistor like the 5457 and 5458?
Note: I never buy parts from eBay for obvious reasons, I only buy from reputable dealers.
And, I realize, that most would just buy any of these parts and not worry about it, but this Old Ovation is my pride and joy; I'm trying to keep the sound as authentic as possible.
Thanks in advance for any help, suggestions, or advice you can provide.
