I am currently designing a modular device for signal acquisition and signal generation. This is not a professional/commercial device. I am only building it out of interest and to learn.
Nevertheless, the device should behave reasonably concerning EMI and I want to avoid the signal acquisition being disturbed by the mains frequency or USB. Unfortunately, I have little experience with this topic, and I hope that you can give me answers to my specific questions.
The basic structure of the device looks something like this where the questions below came to my mind:
Should I connect the protective ground wire of the mains connector directly to the system ground of my backplane or only to the case shield (via a screw)?
Should I connect the shield of the USB connectors to the system ground? (I have measured that both in my USB hub and my PC USB shield and USB GND are directly connected (0 Ohm).)
Should the PCB to case holders (metal) next to the USB connectors directly connect the system ground to the case or should they be isolated?
Should the ground of the single PCBs be connected to the metal front covers (case shield) or should they be isolated from the shield at that point?
Should the ground of the backplane be connected to the case shield via screws or should they be isolated from the shield at that point??
Thank you in advance for your helpful comments!
