If Micro USB B of USB 2.0 is set to Host with USB OTG, is it dangerous if connected to a USB-A-female port that isn't running USB OTG?
From what I understand.. Micro USB B, of USB 2.0 has a pin that enables it to run as host, and that is USB OTG. And some devices with Micro USB B of USB 2.0 haven't connected that pin, and they need an adaptor and the adaptors tend to go to USB-A-Female.
For this question it shouldn't make a difference if there's an adaptor attached or not. So let's say there's no adaptor. Just that the Micro USB B of USB 2.0, is using USB OTG and set to Host.
I want to move from that example for a moment, and establish a few things..
If two USB-A-Female connector of one computer is connected to a USB-A-Female connector of another computer, both are hosts, neither are USB OTG. It's just USB-A-FEmale straight from the motherboard, no USB OTG adaptor. No B connector anywhere. And suppose they were connected with an illegal cable, a cable that is USB-Male-A on both ends. Then from what I understand, that's potentially dangerous.
Now suppose you have a computer e.g. pi zero, or a smartphone, with a Micro USB B USB 2.0 connector. And another such device. You have an OTG adaptor in one making one of them a USB-A-Female. And both devices are set to OTG Host. Then I would think no damage would be done. Clearly it wouldn't work. But I think that OTG circuitry would have taken into account that scenario and no damage would be done.
Now though, back to my question's example.
Suppose one computer/smartphone's USB is OTG and the other isn't, and both are hosts. That's my question of "If Micro USB B of USB 2.0 is set to Host with USB OTG, is it dangerous if connected to a USB-A-female port that isn't running USB OTG?"
And perhaps one consideration is maybe the answer depends on , or has to take into consideration, which version of USB the non-OTG Host is e.g. USB 1 was pre OTG. OTG seems to have been added at some point early within the development of USB 2.0 but after its release. So there could be some early USB 2.0 that don't support OTG and later ones, that do.
Could damage be done?
So, if you see a Micro USB B of USB 2.0 port, that might be set to host. Is it always safe to connect it to any USB port? Safe for the device that owns that Micro USB B port of USB 2.0, and safe for the device it connects to.
