I don't think so. Current batteries (Amazon, Panasonic, off-brand that came with something) measure very close to 44mm (don't forget to add some insulator if you use metal calipers or a micrometer, lol, then subtract off the insulator thickness).
Springs on handheld devices, if poorly designed, can have their yield point exceeded if the device is tossed around or dropped, which permanently shortens the spring. Ideally a molded stop would prevent that. Stretching the spring out past the yield point fixes it, until the device is dropped again.
- 44.07mm off-brand
- 44.16mm Panasonic Alkaline plus
- 44.37mm Amazon Basics
Duracell:
Rayovac:
However note that Energizer has a lower interpretation of the IEC standard by as much as 0.2mm.
If we go back and actually reference the 1959 standard, the maximum dimension for AAA cells is given in metric as 44mm, but in Imperial as 1-3/4", which is 44.45mm. The minimum is given as 43mm or 1-11/16" which is 42.86mm.
ANSI C18.1M, Part 1-2001 ($$$ standard) specifies the length of an AA cells as between 43.3 and 44.5mm, same as Energizer.
So they've tightened up the specifications a bit. If you took the metric dimensions in the 1959 standard as primary (nobody would have at the time) the cells have actually grown a bit.
