When I see TIA schematics, I can see either the photodiode to GND or against VCC. What is the difference?
Asked
Active
Viewed 631 times
1Both of your circuits produce zero bias across the photodiode. If you want reverse bias in the second diagram, set the non-inverting input to GND, and deal with the fact that the output voltage will be below ground. – The Photon Jul 02 '22 at 13:08
1Or use the first diagram, but apply a negative voltage to the PD anode. – The Photon Jul 02 '22 at 13:09
First: photodiode is a current source, which suggests its internal resistance is mighty high...often hundreds of Megohms for a small-area diode.
Zero-bias (GND):
- minimum leakage current and temperature-induced currents added to photo-current
- minimum noise
- highest capacitance, slowing response time.
High-reverse-bias voltage source (Vcc):
- less diode capacitance, for fast response time.
- leakage current is higher, causing DC offset.
In some circuits, the photodiode is placed between op-amp "-" and "+" inputs - this is equivalent to zero-bias operation.
glen_geek
- 23,591
- 1
- 22
- 50
Also it seems the high-reverse-bias, would need a Vref on V-, not on the other case right? – nowox Jul 02 '22 at 11:58
1Any bias supply *must* reverse-bias the diode. The resulting leakage currents are in the same direction as photo-current. So if anode attaches to bias-supply, the supply must be more negative - a cathode attached to bias-supply would require V+. – glen_geek Jul 02 '22 at 12:47
1Reverse bias also widens the depletion zone, which improves the quantum efficiency, especially in the infrared. – John Doty Jul 02 '22 at 19:46
