I'm trying to solve this problem:
A silicon photo-diode has a responsivity of 0.6 A/W at a wavelength of 850 nm. Determine the minimum incident optical power at the photo-diode at this wavelength in order to maintain a bit rate of \$10^{-7},\$ when utilizing NRZ signaling at a rate of 35 Mbit/s.
and I solved it by:
\begin{align*} R=&{0.6}{A/W}&\\ \lambda =& {850}{nm}={0.850}{\mu m}&\\ B =&{10^{-7}}{b/s}&\\ \textrm{BER}=& \exp(N_p)/2&\\ N_p=&\ln (2\times \textrm{BER})&\\ =&\ln (2\times ({10^{-7}}{b/s}))&\\ =& -15.425&\\ P_{\textrm{rec}}=& N_p \hbar \nu B/2 &\\ =& (-15.425)(6.6\times 10^{-34}) \Big(\dfrac{3\times 10^8}{ {850}{nm}}\Big)({35}{Mbit/sec}/2) \end{align*}
However, I've seen answers assuming that \$E=N\hbar \nu /\eta\$, \$E=P_i 2/B\$, and \$BER=e^{-N_p}\$. Any idea why they assumed that?
ocrdu
  • 8,705
  • 30
  • 42
Diana
  • 111
  • First you say the bit rate is \$10^{-7}\$, then you say it is 35 MBps. Which one do you actually want? If \$B\$ isn't the bit rate, what does it represent? What does \$N_p\$ represent? (I'd expect it to be photons per bit, but it's very difficult to produce negative photons) – The Photon Jul 02 '22 at 13:13
  • And where did you see the formula \$\mathrm{BER}=e^{-N_p}\$? I don't think that has the correct limiting behavior at all. – The Photon Jul 02 '22 at 13:21
0 Answers0
