I am using an STM32F072CB. Some of the GPIO pins are connected to a multiplexer for controlling the channel, and others are connected to some MOSFETs. The pins are configured as regular no push/no pull GPIO output pins:
I am having some trouble changing the output of these pins in my code. I know they are correctly connected since if I set their default output ('GPIO output level') they respond and will output as directed.
When I change their values in the code using:
HAL_GPIO_WritePin(GPIOA, ADD_2_Pin, GPIO_PIN_RESET)
or
HAL_GPIO_WritePin(GPIOA, ADD_2_Pin, GPIO_PIN_SET)
The pins simply refuse to change. Using breakpoints I am able to see the code is being reached, but it is as if the pins are constantly being reset to their original state. How can I figure out what is causing this?
