T1: ambient temperature range of -7° to +35°
T3: ambient temperature range of -7° to +52°
Energy usage is power * time, usually in kilowatt-hours. But, that's only part of the story.
The cost is dependent on ambient temperature, duty cycle of the device, and many other factors that affect the duty cycle like thermal insulation quality, thermal leaks, other appliances adding heat to the environment, people adding heat to the environment, ...
If your device plugs in to a wall outlet, there are meters to record power usage of devices over time such as the Kill-A-Watt line of meters. Recording power usage over 1 week will give you a good idea of cost of running such an appliance.
