I am exploring a tentative design to limit current for charging a VFD bus link capacitor from the AC mains. Simple analog current limiters using resistors and transistors are inefficient and problematic when dealing with peak charging current from a full wave bridge rectifier, as I discovered in answering a similar question recently. So I think this will require a switching regulator design using PWM and an inductor. I simulated a circuit using LTSpice that seems promising, but I see very high power spikes when the MOSFET is turned on and off.
This is to be expected, as the device will transition from a condition with as much as 350 V when OFF, to a peak current of up to 20 A in the inductor, so during switching there may be simultaneously as much as 7000 W. LTSpice shows spikes of several thousand watts, but duration is in the order of 100 ns.
I was able to somewhat reduce the amplitude of these transients by using an RC snubber across the device, and with a gate resistor which reduces the switching speed, but both methods dissipate power. I have also found a lot of variation among various NMOS models. When I calculate the average power over a half wave at 60 Hz, it is about 5 W, which is acceptable. But I am concerned about reliability issues due to the high switching transients. I have designed and built similar switching circuits, and they have worked OK, but I'd like some confirmation that these transients might be ignored.
Here is the circuit as it stands. A practical implementation would require a number of refinements, but this is to prove the general principle.
LTSpice circuit simulation
I found that the commutating diode D2 was exhibiting several hundred A of reverse conduction, which caused much of the excessive power spikes noticed. I replaced it with three 150 V Schottky devices and the circuit operation now seems reasonable. Here is the new simulation:
Improved simulation
winny
  • 13,064
  • 63
PStechPaul
  • 7,195
  • If you want less power switching, insert an inductor (1u) just before R2. This will limit the di/dt of the input current. – Antonio51 Jun 24 '22 at 06:04
  • I don't think that will work. There will be continuous DC current and the inductor will saturate. Thanks for the idea, though. – PStechPaul Jun 24 '22 at 07:30
  • It sounds like you need a current converter, like a battery charger. Your buck will have zero galvanic isolation, so I'd recommend a transformer. If you're unhappy with the inefficiency of flybacks, use a forward, or even half-bridge, though know that each comes at a cost. Otherwise, `D1` is the one that causes the problems -- the LC filter is meant to work bidirectionally. – a concerned citizen Jun 24 '22 at 07:47
  • 1uH ->10 uH on air does not saturate ... And for the first period, one can use a soft start (duty PWM=0.1 --> what is needed). – Antonio51 Jun 24 '22 at 07:54
  • @aconcernedcitizen Confirmed for D1 for Duty > 0.6 – Antonio51 Jun 24 '22 at 08:15
    What’s your output voltage? Please don’t connect diodes in series. – winny Jun 24 '22 at 08:48
  • The output voltage will be maximum 350 VDC for 250 VAC input. Duty cycle will be adjusted to control input current and output voltage. This is a mains-connected VFD, so galvanic isolation will be provided for user interface. I could not find anything specifically about Schottky diodes in series, but in general the leakage current and capacitance characteristics should provide reasonable equalization. A fast recovery SiC diode might be better, but simulation showed high reverse current spike. – PStechPaul Jun 24 '22 at 21:52
  • The simulation with a fast recovery commutating diode RFUH5TF6S shows a peak reverse current of 180 A and power spike of 67 kW for 8 nS. This might be an artifact of the simulator and may be OK in actual application. – PStechPaul Jun 24 '22 at 22:27
  • A 10 ohm resistor in series seems to solve the problem. – PStechPaul Jun 24 '22 at 22:40
  • Be aware that when using 3 series diodes, you should add "resistors" to equalize voltages across each. – Antonio51 Jun 25 '22 at 10:28
  • _"Simple analog current limiters using resistors and transistors are inefficient"_ - Why do you care about efficiency? – Bruce Abbott Jun 28 '22 at 04:26
  • They are OK if used only to limit initial surge current, but for AC input they dissipate a lot of power during charging peaks. I have decided to use a couple resistors across the N.O. relay contacts and then close the relay after about 1 second. If the capacitor is shorted, the contacts may be damaged, but the series fuse will blow before other damage occurs. – PStechPaul Jun 28 '22 at 07:42
Absolutely not.
They cannot be ignored but, you can easily check to see if the device you have chosen is suitable. Open the data sheet for the device (R6020PNJ) and navigate to the safe operating area graph: -
The red parts are by me and tell you that the maximum instantaneous power that can be handled by the device is 6 kW providing it lasts for no more than 100 μs.
during switching there may be simultaneously as much as 7000 watts
Find a more powerful device.
It's tempting to think that for your pulse duration (100 ns rather than 100 μs) you can just extend the SOA graph up in stages but it doesn't work like that. In my experience, devices that have the minimum time limit specified as 100 μs are usually weak for most jobs. Most good MOSFETs will have the 10 μs duration plotted and, the peak power will be significantly more than that at 100 μs duration (probably at least 3 times greater and sometimes up to 10 times greater) such as this SiC device from ON semi: -
  • I determined 7000 watts based on maximum 350 volts and 20 amps, but realistically I think the maximum would be half those values, so I should be safe. And I can design for as low as 5 or 10 amps. I chose that device from what was available in LTSpice, so I;ll see what I may have or can order. It looks like the peak power will be under 1 uSec, so probably more than 6 kW would be safe. Thanks. – PStechPaul Jun 24 '22 at 09:10
  • @PStechPaul you can use your simulator to give you a more precise answer. I wouldn't be designing stuff based on "probably"; I'd want to double check. – Andy aka Jun 24 '22 at 09:49
    100ns switching transients don't show on the SOA curve; I don't know why exactly they don't plot less than 10us, but I have never heard any indication there's something wrong with it. Almost every converter on Earth wouldn't work if it can't be done. The total energy is fairly small, so that SOA isn't a good gauge of performance: look at average power dissipation instead. – Tim Williams Jun 28 '22 at 01:19
  • Tim, you can't arbitrarily decide that if the SOA doesn't show it. – Andy aka Jun 28 '22 at 07:20
Yes, this is a fine way to do it, given all the usual caveats of power electronics design, including accounting for stray inductance of the switching loop, peak and average power dissipation, thermal management, current control, and other protective features like mains surge or output faulting.
For example, I've designed and built some limiters myself, albeit for a lower power level -- 30V 20A:
Photo of current limiter module and PCBs
These use two transistors anti-series, with a hysteretic current mode control, to implement bidirectional current limiting. Switching is done at around 200kHz, and is limited to a fault duration of 150ms, or until the clamp diodes overheat. An optional ground-return connection can be used to save power dissipation, allowing more fault cycles before the thermal limit kicks in. Finally, the optimized discrete circuit design draws minimal supply current, giving a lifetime of some months continuous operation on a 9V (PP3) battery. (This is rather unimpressive on the whole, actually, but I didn't see any ICs available to implement this function, so had to build it myself(!). Doing it from common ICs (logic, comparators, gate drivers) would give significantly shorter battery life. Go figure!)
A similar approach could be applied for commercial/industrial voltages and currents as in your application, given suitable design changes -- probably the discrete circuit wouldn't be so practical anymore, and an auxiliary supply would be available to power the controls. Bigger transistors would be required of course, especially with mains surge requirement in this location -- probably something like 1200V SiC MOSFETs, with a MOV at the input, would do. And with thermal protection, and a free ground return path (no clamp diodes required, as in my inline case), a compact design should be quite reasonable.
Incidentally, notice the inductor can be quite shite. Core loss is essentially irrelevant; even if it has a Q of 5 (typical for #26 powdered iron around 100kHz), it's only active for some hundreds of ms, and out of the several ~kW (DC) delivered, it dissipates, well, about 1/5th of that, but that's only a few paltry J of energy, out of a big chunk of iron/copper/ferrite -- it'll barely heat up.
The main reason you don't see these sorts of things, by the way: they're simply added cost. You need a BIG transistor to handle that much (steady state) power, plus precharge, plus surge. An NTC resistor, and optional bypass relay, is so much better value.
Tim Williams
  • 22,874
  • 71
