I am currently studying DCDC stability analysis in LtSpice. Could you please check my phase margin calculation, am I right? And how about the gain margin calculation? Is it equal to infinity in my case? This buck converter I checked, works well in transient modeling. To calculate PM I put the AC probe source between the system output and the feedback resistive divider, and after simulation, I created a custom plot of Vout divided by Vin_m (opamp negative input voltage). Is that the correct way to calculate phase margin? According to my calculations, PM = ~22 degrees, and the crossover frequency = ~23 kHz. Bode plot with marker lines
UPD: I changed my schematic according to LvW suggestion, now I am not sure what net I should measure on the bode plot:
New schematicNew schematic bode plot
    Are you using a switching circuit to which you've added an ac source for a .AC analysis? Ac analyses in SPICE only work for linear circuits, e.g. non-switching circuits. In your case, you will have to reconstruct your circuit with an averaged model - the PWM switch for instance - and then ac-sweep the whole thing. Look at the examples in this [document](https://cbasso.pagesperso-orange.fr/Downloads/PPTs/PWM%20VM%20into%20CM.pdf) from my webpage. You can also resort to the FRA capability of LTspice but that is quite tedious. In your case, an averaged model is the right way to go. – Verbal Kint Jun 17 '22 at 13:53
    Independent on the problems as mentioned by Verbal Kint, you loop gain simulation is NOT correct. You must break the loop (for introducing a test signal) at a point where a very small source resistance (e.g. opamp output) was connected to a much larger load impedance. Otherwise you cannot simulate the correct loading conditions of the closed loop. – LvW Jun 17 '22 at 14:25
    Sounds like a [duplicate](https://electronics.stackexchange.com/q/529358/95619). – a concerned citizen Jun 18 '22 at 12:52
0 Answers0
