I'm planning to use the MAX 6644 for a simple fan control application. All in all the IC is very straight forward to use. However after analyzing the typical application circuits in the datasheet I have doubts as to the circuit can actually work.
The problem I see is that the PWM signal switches a transistor in the negative supply wire of the fan. As far as I know, the TACHO output of most fans is open-collector and therefore references to the negative supply. If now during operation the transistor is switched off, the open-collector TACHO signal of the fan would now be at positive supply of the fan (e.g. 12V) correct? That would mean the IC can detect the short TACHO signal pulse only by chance if it occurs during the active phase of the PWM transistor.
Did someone already use this IC in the typical application circuit as provided by maxim and can confirm that it works?
