I want to measure the open circuit voltage of a battery cell (differential reading, that is A0-A1). In order to do that, I am using an industrial PLC based in Arduino Mega and a cheap but accurate ADC (ADS1115). I need to get an accuracy of 100uV (which I should be able to get with ADS1115 by far). However, due to some unexpected noise/currents, my accuracy is only 0.01V (really bad). This means that, if I want to measure for example 1.3005V, I get one second 1.3005 volts, the next second I get 1.3030 and the next second 1.2980 and so on. I know that the real voltage value has not changed at all, as I am checking its value with a BTS system (big and expensive separated equipment). I cannot have so much change in so little time, specially changing from increase to decrease in value. I need the measurement to be completely stable along time. Averaging the value alone is not an option.
This is my set up. Note that I am using a breadboard to connect everything.
Some comments which can help to the diagnosis:
  1. Could the problem be caused by the grounds? As I understand, with this set up I am having common grounds, and this could add current paths and create noise. I have read that it is recommended to isolate the analog ground (ADC) from the digital ground (PLC) by adding an isolator. Could this help? Anyways, I have read that an ADC has one digital ground but also an analog ground. However, in the ADC datasheet I find only one ground (the analog), which comes from the PLC.
  2. Could the problem be related with common Vdd? I mean, the same power supply is used first by the PLC, and then, the PLC gives the Vdd to the ADC. In the past, there was even no external power supply, so the ADC was powered by the proper Arduino Mega by the USB cable. This generated some big variations in the ADC reading that improved after adding the power supply. Please, note that the USB cable is always connected and with traffic (for debugging use only).
  3. I have read on this thread that it is a good practice to add an small capacitor to the ADC input to hold the signal. Could this help? I have not added one in my set up.
  4. ADS1115 datasheet suggests to add an small cap (0.1 uF) to decouple Vdd. Do I still need to to this, even though that Vdd comes from the PLC?
  5. Also ADS1115 datasheet suggests: Analog inputs with differential connections must have a capacitor placed differentially across the inputs. As I am doing a differential measure, could this improve the reading?
  6. I have already tried to add a low pass filter to one and both ADC inputs, but the measurement variation got worse!
  7. IMPORTANT UPDATE: As i briefly mentioned in the beginning (but I didn't put it in the drawing) I also have a Battery Test System (BTS) connected to the battery cell in order to charge/discharge it. This BTS operation is the following: it provides positive current (around 300 mA) during charge cycle, and then for the discharge cycle it provides -300 mA, then charging again, discharging, and the loop goes one like this. I say this right now because, when I tried to connect the (-) side of the battery (=A1) to the analog ground as some people have pointed out, it removed the noise. HOWEVER, during discharge cycles, a voltage drops appears and the battery loses a lot of its capacity (which is not feasible). As one person has suggested, maybe this is because the current is able to have a path and then it creates a voltage drop? Is there an easy way to avoid this current?. This is the set up with the BTS included:
bardulia
  • 377
    Keep in mind that **precision** and **repeatability** are not the same as **accuracy**. There are several sources of error in the ADS1115 and it looks to me that you will be doing very well if you can achieve 14 bits of accuracy. Note that the worst-case gain error alone is 0.15% – Elliot Alderson Jun 15 '22 at 23:18
    Am I right in saying you've literally connected the battery positive to A0 and negative to A1, and there's no other connection between the battery and your circuit? That ADS1115 is the adafruit module? If so, that whole battery setup is floating, and while there may indeed be a fixed voltage difference between A0 and A1, the value of either with respect to your ADC's ground is undefined. A0 and A1 are flopping up and down (in unison) like two glued-together leaves in a breeze. – Simon Fitch Jun 16 '22 at 03:40
    Regardless of what you do to improve the circuit, you should apply a low-pass filter in software, given that your sampling rate is vastly faster than any realistic battery voltage changes. – Matt Timmermans Jun 16 '22 at 13:00
  • @ElliotAlderson you are right about that. I am Spaniard and we only have one word in Spanish for precision/accuracy. And yes, with 14 bits should be enough. – bardulia Jun 16 '22 at 14:55
    1. Yes. Show schematic and layout. 2. Yes. See above. 3. Depends on your speed requirements. Some ADCs are very hungry for input current when sampling. 5. Probably yes. 6. Show measurements and schematic please. – winny Jun 16 '22 at 14:56
  • @SimonFitch Yes, you are right about how the connections and Adafruit module. – bardulia Jun 16 '22 at 14:57
  • @MattTimmermans I have configured the ADC to sample at 8 samples per second. Then Arduino reads this data only every 2 seconds. Battery voltage change is around 0.5 mV per second. I would not like to do any averaging in the samples (this is a LPF right?). – bardulia Jun 16 '22 at 15:02
    @bardulia Averaging is a "moving average filter", not a LPF. There's a difference. For you though, either would help. It's better to read at 8 samples per second in the Arduino, and average 16 samples when you need to use the data. – Graham Jun 16 '22 at 15:08
  • @Graham I would like to do the average only when I am sure that the signal is the best clean and real possible, but sure. – bardulia Jun 16 '22 at 15:29
  • @winny I still don't have the schematic/layout. Could you please recommend me a program/format to do it as it is regular done in this forum?. Regarding you second answer, can you check my answers to it?. Regarding 3, I only need to sample every 2 seconds or so, and I have set the ADC to sample at the lowest speed (8 sps). Regaring answer 5, how do I place this cap/s differentially in the inputs? any similar example I can check?. Regarding answer 6, I will do it. – bardulia Jun 16 '22 at 15:40
  • I have updated the question with the BTS system that I didn't talk about before (point 7 of the diagnosis comments). – bardulia Jun 16 '22 at 21:58
A differential measurement still needs a ground reference point, due to how most ADC front ends/signal conditioners are designed.
You need to connect the (-) side of the battery to both one analog input and to GND of the ADC module.
The decoupling capacitor on the supply rail to the ADC is always needed. Sometimes you need two of them for good performance. The capacitors need to be on the PCB where the ADC is. They won't do much good if they are connected via the impedances present in typical breadboard construction.
    Pretty sure this is the right answer. Simple to fix too. I'm not sure if I understood your "fix" though. Connect battery negative to ADC GND and battery positive to A0. I assume that's what you meant. – Simon Fitch Jun 16 '22 at 04:04
    @SimonFitch There is some advantage to differential input in spite of one side being grounded. So (-) goes to A0 and GND, (+) goes to A1, ADC is configured for differential input. – Kuba hasn't forgotten Monica Jun 16 '22 at 04:21
    I'm not sure I see what advantages there would be. Care to elaborate? – Simon Fitch Jun 16 '22 at 05:51
  • @Kubahasn'tforgottenMonica your answer was something that I have already tried. As you said, I connected the ground from the 24V power supply to the PLC, from PLC to the breadboard, and from bb finally to (-) side fo the battery. This removed the noise during both charge/discharge cycles of the battery, HOWEVER during the discharge cycles there was an energy consumption big enough so that the battery lost a lot of its capacity (not feasible). He explaned to me that with this connection there is a current that creates a voltage drop. Maybe the ground connection is a good way but incomplete? – bardulia Jun 16 '22 at 15:09
  • @SimonFitch I think that we are talking about the same, right? – bardulia Jun 16 '22 at 15:13
    @bardulia I see now that the last time you asked this question you were told that you need a ground connection to complete a circuit. This is absolutely true. Reconnect the ground so that the ADC can function. If that causes problems (which it will not if your drawing is accurate), ask why in your question. – user1850479 Jun 16 '22 at 17:15
  • @user1850479 Sure. I did the ground connection and the noise dissapeared during both charge/discharge cycles of the battery. HOWEVER during the discharge cycles there was a voltage drop big enough so that the battery lost a lot of its capacity (not feasible). This is because the battery is also connected to a Battery Test System that provides positive current for charging cycles and negative current for discharching cycles (one each at a time in a loop). Any idea on how to avoid this voltage drop?. – bardulia Jun 16 '22 at 21:34
    @bardulia Your new drawing shows that the battery test system is powered by the battery you are testing. Is that correct? – user1850479 Jun 16 '22 at 22:04
  • Sorry about my bad drawing. The BTS is "powering" the battery cell by means of charging/discharging it. BTS has its own power supply. – bardulia Jun 16 '22 at 22:07
  • I have some progress. Find the new schematic here postimg.cc/PNj2dxXD The measurement has improved a lot because right now I have 1mV accuracy. The only problem I still got is that, once in a while, I get an spike in the measurement around 0,2mV but in the opposite direction of the charge/discharche cycle. My feeling is that the ADC is not able to hold the value sometimes. Any ideas?. I guess I can try a differentical cap at the ADC input but I don't know how to calculate its value (for example, the cut-off frequency, as the datasheet says). – bardulia Jul 22 '22 at 23:03
Question 1:
I do not expect ground currents in your analog path that could mess up your readings. The ADC is at an end point of the supply path.
Question 2 and 4:
Yes, absolut possible. A series inductor of 10-100 µH and a capacitor of at least 100 nF at the ADC supply side are good style. This improves the performance of the voltage reference and the amplifier inside the ADC.
Question 3 and 5:
This is true for ADCs, that do not contain buffer amplifiers, like most ADCs integrated in microcontrollers. And it may help on noisy or high impedance signal sources. Your system has a buffer amp in the ADC and the differential noise from a battery should be very low. Summary: This will probably not help.
BUT we can expect a large common mode voltage noise. The battery is not connected to a reference point of your circuit. It has a random floating charge and receives all sort of noise from the environment. The common mode input resistance of the ADS1115 is 6 Mohm in this mode and can not deal with this noise, which can reach several volts in both directions.
The voltages at the ADC inputs may temporary leave the allowed range and the difference seen by the ADC is lower in this case.
The quick solution is to connect battery minus (=A1) to ADC AGND. This way the circuit is no longer a bipolar instrument.
If you want the ADC to operate more in the center of the input range, provide a voltage divider with 2 equal resistors between VDD and AGND and connect this to A1. A capacitor of some µF between A1 and AGND will cancel the common mode noise. This solution allows bipolar differential measurements.
Jens
  • 5,598
  • Regarding your answer about questions 2 and 4: I will try it. Do you also recommend to have a different power supply for the ADC?. Because right now it is comming from the same source as the PLC. Regarding your answer about question 3 and 5: I already tried to connect the ground (coming from power supply -> PLC -> ADC) to the battery minus (=A1) and the noise dissapeared, however during the battery discharge cycles a voltage consumption appeared with reduces the capacity of the battery (not feasible). Any idea on why this happpens?. Finally, I will try also your last paragraph proposal. – bardulia Jun 16 '22 at 15:22
    @bardulia You can use an isolation DC/DC converter for the ADC if your PLC is in an industrial rack with a lot of other components, but typically good L/C filtering is good enough. Can you explain the "voltage consuption" during discharge more in detail? Probably my last paragraph solves this. – Jens Jun 16 '22 at 15:50
  • Right now the PLC is not inside an industrial rack but in the future it will. Regarding "voltage consumption": I am doing charge/discharge cycles to the battery using another device (a Battery Test System or BTS), and I want to measure simultaneously the battery voltage. This BTS provides a positive current to the battery (charge) and a negative current (discharge), one cycle of each and then repeat in loop. This "voltage consumption" only happens during discharge, probably because the negative current now has a alternative path because the ADC impedance is not big enough? – bardulia Jun 16 '22 at 16:34
    @bardulia I assume the separate BTS is not fully isolated from your PLC GND. Its activity can mess up your meaurement and the BTS does not expect to have external current paths to somewhere else. It could react erratic. In this industrial context you should use an insulated DC/DC converter to feed the ADC and use digital isolators like e.g. ADuM1251 for the I2C communication. Make the ADC a DC island. – Jens Jun 16 '22 at 18:38
  • that makes sense! I will try the insulation you proposed and let you know. – bardulia Jun 16 '22 at 21:35
  • Jens, I have bought a DC/DC converter to power the ADC, and for the I2C communication I have bought the ADUM1250 mounted on an evaluation board (the only one in stock). However, there is no communication, I think because I have not connected any ground to the evaluation board. Do I need to put the analog ground to both grounds of the board/adums1250 chip? – bardulia Jul 18 '22 at 16:18
    @bardulia I don't think so, but I would like to see the new schematic for a qualified answer. – Jens Jul 18 '22 at 17:10
  • you are probably right! I will re-check everything and post the new schematic. Thanks! – bardulia Jul 19 '22 at 11:02
  • Jens, I have some progress. Find the new schematic here postimg.cc/PNj2dxXD The measurement has improved a lot because right now I have 1mV accuracy. The only problem I still got is that, once in a while, I get an spike in the measurement around 0,2mV but in the opposite direction of the charge/discharche cycle. My feeling is that the ADC is not able to hold the value sometimes. Any ideas?. I guess I can try a differentical cap at the ADC input but I don't know how to calculate its value (for example, the cut-off frequency, as the datasheet says). – bardulia Jul 22 '22 at 23:03
    @bardulia 200uV spike is not far from the resolution of the ADC, improving this is a challenge. You can try 2 x 10 ohm in the input path and 10 nF across the inputs. Another attempt I often use is to buffer the results and replace the artefacts by the mean value of the adjacent values. You can easily double the sample rate to implement this. What voltage range for the PGA do you use? The ADC uses oversampling, so you don't know if the spike is one single large impact or several small deviations in one oversampling interval. A much higher sampling rate could show this. – Jens Jul 23 '22 at 02:56
  • I will try the RC filter you suggest! how have you calculated the cut-off frequency? it depends on the input sampling rate or on the ADC internal clock?. Regarding the resolution, I have already been playing with the PGA but it does not improve this last issue of the 0,2mV. On the other hand, I like your idea of the buffer+mean, specially because I can do it easily. Right now I am printing a result each 2 seconds to mimic the BTS readings, but I can for example easily take 4 samples every 0.5 seconds and then compute the mean value to print it out. – bardulia Jul 24 '22 at 14:05
    @bardulia This RC filter is just a blind shot for typical RF noise. If you don't know the nature of the artefact, it is hard to fight it. Could as well be a large common mode impact, which would need two capacitors to GND. Try to catch such an event with a scope or make some extra EMI noise with mobile phone, drilling machine etc close by. – Jens Jul 24 '22 at 14:26
  • Jens, I tried with RC filters but there was no improvement. I think that it is a large common mode impact or a voltage drift maybe coming from the BTS. I forgot to mention that I am using ADS1115 from Adafruit which already has decoupling capacitor from Vdd to ground (https://learn.adafruit.com/assets/112763). I also tried with an ADS1219 (the evaluation board) but the noise is still the same. What can I check to improve?. Could be that there is a drift coming from the BTS that enters to the ADC?. Tomorrow I will create a new question with the last set-up so everything can be check easily. – bardulia Mar 17 '23 at 22:09
    You have a relative low sampling rate. Assume there is a periodic artefact, which you don't hit most of the time with your ADC. Your impression might be, that the artefacts are at random times while the source in reality is a frequency. I once hunted such a problem and finally identified the periodic heater turn off of a solder station as source. – Jens Mar 19 '23 at 23:13
Yes and the cabling could also do this. Current going back through the cable between the ADS and the PLC can cause voltage differences on ground. Know what the current is and use a decently sized wire (the resistance in the wire will create voltage noise V=IR)
Could the problem be related with common Vdd? Yes, measure the ripple and then look at the PSRR and calculate the noise. PSRR is a figure that tells you how much the power supply will affect the measurement.
Adding filtering (not a capacitor) helps in rejecting noise, you can't filter everything though because you will start filtering signal. This must be calculated
ADS1115 datasheet suggests to add an small cap (0.1uF) to decouple Vdd. Do I still need to to this, even though that Vdd comes from the PLC?.
Yes you do, it will help with noise from power and ground and common mode noise from cabling. Ideally you should have a voltage regulator next to the ADS (and your reference should be on the same board if it needs one)
I would do what the datasheet says.
If you are doing a differential measurement, you need a differential LPF, if you only filter one side then the noise will not be subtracted differentially and will look worse in most cases.
Neil_UK
  • 158,152
  • 173
  • 387
Voltage Spike
  • 75,799
  • 80
  • 208
  • Regarding your first paragraph, that is exactly what happens when I connect the ground to the negative side of the battery: a current appears and I get a high voltage drop which affects negatively the capacity of the battery (not feasible). This only happens during battery discharge cycles (not during charge cycles). On the other hand, I will try all of your suggestions one by one to see if it improves. – bardulia Jun 16 '22 at 15:26
  • I have updated the question with the BTS system that I didn't talk about before (point 7 of the diagnosis comments). – bardulia Jun 16 '22 at 21:59
  • Right now I am feeding the ADS1115 with a DC/DC converter. Would it be better to feed it with a voltage reference IC?. – bardulia Sep 20 '22 at 14:58
    Yes, DC DC have more ripple. PSRR of the ampliifier describes how much of the power supply ripple will get through to the signal – Voltage Spike Sep 20 '22 at 15:47
  • I have checked deeply the ADS1115 datasheet and it already has an internal voltage reference. So I guess that the external one is not needed? What I have done is adding the decouple capacitor to the Vdd as the datasheet specifies. – bardulia Sep 30 '22 at 10:13
    Yeah, that would be best – Voltage Spike Sep 30 '22 at 13:19
You need an anti-alias filter in hardware
You say
Filtering/averaging is not an option
However if you don't low-pass-filter in hardware at the Nyquist rate or lower, aliasing is going to seriously mess up your measurements. As VoltageSpike says, for a differential signal you'll need filters on both sides of the signal.
According to this link the ADC can sample at up to 860Hz. So all the noise above 430Hz (or whatever speed you measure at) is getting "reflected" back down. This isn't going to be pretty. Just by the way, this is one of the reasons that early CDs in the 1980s had a bad reputation, because they hadn't properly worked out anti-aliasing on the ADCs back then.
You would benefit from filtering in software
Battery voltage doesn't change that quickly, so consider how fast you genuinely need this to respond. If you're sampling at 5ms intervals but you only need the data every 100ms, a digital low-pass filter in software will definitely improve your signal.
Graham
  • 6,020
    The OP should note that software filtering can improve **resolution** and reduce the effects of random noise, but it can not remove systemic errors and improve **accuracy**. – Elliot Alderson Jun 16 '22 at 15:01
  • @ElliotAlderson I agree on that. For me, resolution is not an issue as sometimes I can get the one expected, it is an accuracy and error issue. – bardulia Jun 16 '22 at 15:23
  • Graham, right now I have set the ADC to sample as slow as possible (8 samples per second), because I only need to take samples every 2 seconds or so. I already tried in the past to set a hardware LPF (RC one) around 50Hz, but the results were worse. I have to retry it anyways because maybe the layout was not correct. – bardulia Jun 16 '22 at 15:35
  • I hesitate about the cut-off frequency for the anti-aliasing filter: some people recommend to start from the data rate (for example, por 860 samples per second, use 860 Hz), but others from 10x the data rate value. What are your thoughts about it?. – bardulia Jul 24 '22 at 23:04
    @bardulia Both are simply wrong, so whoever those people are, ignore them as sources of advice! :) If your sample rate is 860Hz, you should have an anti-aliasing cutoff at 430Hz (Nyquist) or slower. It's that simple. – Graham Jul 25 '22 at 14:10
    @bardulia Theoretically, if phase response is an issue for you then you might choose to cut higher and accept that you're going to let through some extra noise. This would only be for highly specialised applications, and would be an engineering judgement of accepting higher noise to get a filter that lets the signal through faster. It is not, ever, something that should be done all the time. Anyone who suggests that is literally so ignorant of the subject that they don't even know what aliasing *is*, and that's the level you should believe their advice. :) – Graham Jul 25 '22 at 14:15
  • @Graham I come back to you because I am finally doing the LPF by hardware. I found your comments so helpful! Finally I am sampling the ADC at 860 sps, so as you pointed out my cut-off frequency will be 430 Hz. I have thought about implementing the LPF with a simple RC filter (one for each input signal so two in total), do you recommend me this type of filter? One of my colleagues has recommended me to use a suitable integrated circuit filter. Do you think that the IC would improve the filtering? If so, any recommendation of specific ICs to use?. – bardulia Sep 15 '22 at 16:40
