I'm using Altium Designer 22 to design a PCB. On the top layer I have a ground plane with a hole in the middle. I made the hole by using a polygon cutout. Now, I have to pour into this cutout region some polygons, but I'm not able to do this. Do you have any solution to address this issue?
JYelton
  • 32,302
  • 134
  • 249
If there's a polygon cut-out then you can't.
One solution is to draw the polygon manually in a way that it has that hole:
I have exaggerated the top gap but sure the edges should kiss each other.
Rohat Kılıç
  • 26,954
  • 67
Three options:
  1. As mentioned, shape the ground polygon so it avoids the area.
  2. Delete the cutout and place the desired polygon; set pour order on the manager so it pours first. GND will clear around it.
  3. Do as #2, but reshape/place a new cutout so it clears the border between polygons. (Now the exact shape of both polygons is less critical, and clearances can be set manually by its shape.)
2a: Do as #2, and set clearance rule between nets, or polygons, or whatever exactly you're after, to do the same as #3 but automatically. This assumes the clearance is uniform, of course.
Tim Williams
  • 22,874
  • 71
