-1
Here's my setup:
I'm trying to emulate the circuit to the right with the one on the left. That is, the one on the right is a pre-charged capacitor (node3) being discharged to its capacitor pair via a resistor (at this point, I'm asking about \$I_{max}\$ of the equation $$I(t) = I_{max} e^{-t/RC}$$.
The experiment on the left has the same setup, only it's an Arbitrary Behavioral Current Source, instead of a resistor, and it's not working as the one on the right.
What's wrong?
ocrdu
  • 8,705
  • 30
  • 42
Dehbop
  • 279
Your title is as much of an XY problem as it can be. What you want is an emulated resistor, not a specific help about behavioural sources. Your expectations are also wrong: a resistor is not a current source. But if you want a resistor to be emulated by a current source then you need to apply Ohm's law: I=V/R -- currently, you discarded V and only used R (or an attempt at 1/R). So, to correct the problem, you have to use V in the equation, and it can be done in two ways:
emulated resistor
B1's expression is V(a,b)/1k, where V(a,b) is V and 1k is R (considering R1 from your circuit). G1 is a 4-terminal element, whose two inputs are connected across the output, forming V(a,c), which is the V. Its value is 1m which is 1/1k. The two behavioural sources below show the equivalent value of the two emulated resistors (green labels) -- they are 1 kΩ, both.
a concerned citizen
  • 21,167
  • 40
