As the title says, what does the 'C' marking mean? I first figured it may be the terminal that outputs temperature data but I'm not sure. I wanted to build a custom solar charger for this battery and I was hoping to know if this terminal is important in any way.
Asked
Active
Viewed 1,343 times
That's the Sony A7 etc. battery. There is circuitry including a microcontroller inside the battery package. The C likely stands for "communication". Communication is digital. Maybe someone has reverse-engineered it and published the results- as far as I know it's proprietary to Sony.
Sony calls their battery communication system InfoLITHIUM.
Spehro Pefhany
- 376,485
- 21
- 320
- 842
Thanks, [this](https://randybuildsthings.wordpress.com/2013/02/25/sony-infolithium-m-teardown/) is not a reverse engineering but more like a teardown and some attempts to see how it works. Since the battery is not just the battery but already has some charging circuitry built into it, would simply connecting the + and - leads to my solar charger work? – user3418620 May 30 '22 at 06:25
1I don't know that it has "charging circuitry" built in. 7.2V appears to be two cells in series. Maybe you could look at what is inside the Sony chargers. – Spehro Pefhany May 30 '22 at 06:58
NP-FZ100 is the battery supplied with Sony α9, α7R III, α7 III, a9 II, a7RIV, a7S III, a7C cameras.
The terminal marked 'C' is for serial communication to display the remaining charge of the battery on the camera's LCD screen.
vu2nan
- 15,929
- 1
- 14
- 42
Thanks. Yep its for my A9. However, if I do not need to display the remaining charge, I could just not use the C terminal right? – user3418620 May 30 '22 at 06:18
2@electrophile yes, it is **probably** save as long as you make sure your charger does not damage the battery (not drain it, not overcharge it, not charge it with too much current). – kruemi May 30 '22 at 06:27
Should the 'C' terminal not make proper contact, an error message would be displayed instead of remaining charge. – vu2nan May 30 '22 at 06:27
@vu2nan, I don't need the remaining charge to be displayed on the charger anywhere. My solar charger is likely to be based on TI's [BQ24650](https://www.ti.com/product/BQ24650) which would anyway monitor charge levels. – user3418620 May 30 '22 at 06:30
During charging, using the matching Sony charger, the state-of-charge and battery temperature may be communicated to the charger. With only the +ve and -ve terminals connected to another charger, there would be no means to monitor even the battery temperature at the very least. – vu2nan May 30 '22 at 07:35
