I will use AD9361 as a transmitter of a modulated baseband signal. The modulated baseband signal is implemented in FPGA/SDK.
AD9361 has real-time bandwidth of 56MHz but we have maximum 61.44 MSPS data rate even if 1RX1TX is used.
This is obviously the maximum data rate at the I/O port of the AD9361. What does that mean for the actual data rates of the signal to be sent?
Which data rate would be achievable ?
AD23
  • AD9361 has a maximum ANALOG bandwidth of 56 MHz. So, while you can clock data at a higher rate the signal will be limited by the analog bandwidth of the transceiver. – johnnymopo May 26 '22 at 17:13
0 Answers0
