I was making some research on GaN and I do not understand why GaN is so reveolutionnary. When I take a look on the following specification RdsOn and Coss (Cds + Cgd), the GaN semiconductor has lower performance than the Si IGBT on RdsOn. About the Coss/Coes the test condition are not the same and it is a bit harder to compare
Here is the GaN specification (LMG342xR030) enter image description here
Here is the IGBT specification (SK75GD066T)
So why the GaN is so revolutionnary?
https://www.semikron.com/products/product-classes/igbt-modules/detail/sk-75-gd-066-t-24912420.html
https://www.ti.com/lit/ds/symlink/lmg3422r030.pdf?ts=1652979339992&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FLMG3422R030
Thank you very much and have a nice day!
-----------------------E D I T ------------------------------------
According to the comments, I changed the GaN datasheet and the IGBT datasheet for helping the comparaison between the both.
I decided to compare the IGBT IKD06N60RATMA1 and the GaN LMG3410R070.
Here are the respective datasheets:
https://www.mouser.fr/datasheet/2/196/Infineon-IKD06N60R-DS-v02_05-EN-1226890.pdf
https://www.ti.com/lit/ds/symlink/lmg3410r070.pdf?ts=1653036430455&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FLMG3410R070
Firstly as Hearth told me, the equivalent modele of the IGBT is not the same than the GaN HEMT. I decided to consider the output characteristics for comparing the power dissipated through the semiconductor.
Here is the one of the IGBT:
So at 18 A it has a voltage drop of 2.4 V @ Vge = 20 V (best case), it means a power dissipation of 43.2 W.
Here is the output characteristics:
It is fairly linear and it seems to correspond with the RdsOn given into the datasheet:
So for 18 A through 70 mOhm, the voltage drop is 1.26 V. So the dissipated power is 22.68 W, which give a ratio of 1.9 between the both devices.
What about switching losses?
Firstly how it is characterized?
For the IGBT:
For the GaN :
It will be hard to compare the both as we do not have the all parameters of the circuit. Nevertheless I hope that it will give us a tendency:
Here are the characteristics:
For the IGBT:
Psw = (Eoff + Eon)/Fsw
For Fsw = 20 kHz (maximum frequency for this king of IGBT) -> it gives 28.6 W.
For the GaN:
For Fsw = 20 kHz -> it gives 1.7 W ... For having the same switching losses i could multiply the frequency to approximately 17, ie 340 kHz.
What is strange is that Coss is not 17 times lower than the Coes (even if it not the only parameter about switching losses). The capacitance of the GaN is higher than an IGBT:
Here is for the IGBT:
Here is for the GaN:
![enter image description here]!
How do you explain it?
Thank you
Jess
  • 2,694
    That's not a great "apples to apples" part selection - one is a 3-phase bridge driver, and the other is a transistor with an integrated driver. Additionally, (lateral) GaN devices don't compete well with (vertical) Si IGBTs - they're not competing for the same operating space – W5VO May 19 '22 at 18:12
    You seem to have forgotten that rCE isn't the whole story when it comes to IGBTs; you also need to consider Vce,sat. – Hearth May 19 '22 at 20:18
  • Also GAN is way faster than IGBTs, especially at turn off ,so you can switch at much higher frequencies resulting (for many applications) in smaller solution size and much reduced switching losses. There's anti-parallel diode required and no reverse recovery loss either, though the conduction loss in the reverse direction is high. That can be minimized using minimal deadtime because of the fast switching. EMI can be challenging though! – John D May 19 '22 at 20:58
  • Si IGBT are simpler to control, higher voltage, but low frequency (10s kHz). Al/GaN Schottky-FET are high frequency (Ft up to 10s GHz, higher working temperature, higher power density due to this and low body resistance and ability to use highly thermal conductive substrates (SiC, sapphire) and good strength to ionizing radiation. – Vladimir May 19 '22 at 21:40
  • @W5VO I agree with you. I will find a more apples to apples part selection – Jess May 20 '22 at 08:43
  • I will take into account all your remarks and I will be back with an EDIT for a better comparaison :) – Jess May 20 '22 at 08:54
  • @JohnD Please see my edit about output capacitance. – Jess May 20 '22 at 16:48
0 Answers0
