Where is the positive and negative on a telescopic antenna? The image below (from a previous stack exchange question) shows a dipole antenna's positive and negative.
Can someone please post a similar picture, but for a telescopic antenna which shows where the positive and negative are for a telescopic antenna?
JRE
  • 67,678
  • 179
  • @user_1818839 Don't write _answers_ in the comment section. You have now made every other answer redundant but OP can not mark it as accepted. – pipe May 19 '22 at 13:55
  • Isn't it the same thing as your diagram except the one half is imaginary behind a ground plane? – DKNguyen May 19 '22 at 14:26
By grounding one end of the half wave dipole antenna shown in the question, one can obtain a quarter wave monopole antenna.
And a whip antenna (including telescopic antenna) is a type of monopole antenna.
So just cover the half of the gif with your hand and you'll get the radiation of a whip (or a telescopic) antenna.
The polarisation changes from horizontal to vertical, though.
Rohat Kılıç
  • 26,954
  • 67
Halfway between left and right halves of the \$1/2 \lambda\$ dipole is a point in space that has zero electric field. This is shown by the green line in the picture below: -
So, you can discard 50% of the dipole antenna and drive the remaining 50% with respect to a ground-plane (formed from the green line above): -
The above images from this answer with a fuller explanation (and quite possibly where the image in the question came from).
This new antenna is known as a monopole and, a telescopic antenna is a monopole. The ground-plane need not be a full-plane and can be formed by the body of a radio receiver and the presence of a human body (in the case of a walkie talkie) or from a counterpoise like this: -
Image from this useful document on antennas
