I am working on the selection RJ45 connector for MDI interface between PHY and the link-partner. I am planning to use this PHY for my SGMII interface application. From various online readings, I understood some RJ45 connectors can have CT (Center tap) pin connection to a power supply to bias MDI signals. I just want to clarify if I have to select RJ45 connector with CT power supply to bias the MDI signals?
For the RJ45 connector selection, I would like to know what is the common-mode voltage of MDI signals (which I could not find in the datasheet). Is MDI signal common-mode voltage a standard value or it will change based on the selected PHY?
