I am building a project where I use 4 stepper motors. Since they require a lot of power I am considering using a Lithium-Ion battery for them.
This is what I was looking at:
https://www.onlybatteries.com/showitem.asp?ItemID=22517.128&cat1=&uid=
Here are the specs from the link:
Li-Ion Size: 3 x 18650 (cylindrical)
Capacity: 3500 mAh
Chemistry: Lithium Ion (Li-Ion)
Working Voltage: 11.1v / 10.8v
Peak Voltage: 12.6v
Cut off voltage: 7.5V
Max Charging Current: 2.1 Amp
Max Discharging Current: 4.2 Amp Limited by Polyswitch
Length: 2.75" (70mm)
Width: 2.17" (55mm)
Height: 0.8" (18mm)
Weight: 5.3 Oz
Features:
No memory effect
Longer storage life then NiMH Batteries
Light weight and higher energy density than any rechargeable battery
Installed PCB (4 Amp) will prevent the battery pack from over charge (> 12.6V), over discharge(< 7.5 V), Overdrain (> 4.0Amp) and Short Circuits. It helps protect battery chemistry integrity and prolongs battery life.
4.2 Amp polyswitch installed to limit max. discharging current at 4.2 A and to protect wrong polarity.
The battery module is wrap by PVC shrink and with 22 G wire leads
The battery looks good, I like that it has protection circuit that prevents over charge and over discharge. It also prevents short circuiting the battery.
However it does not have the connector for balanced charging. How much of an issue is that? Will that cause me problems down the line?
