I have a PCB assembly where I built the circuit in the schematic below. I did not start programming yet.
I'm getting the weirdest problem. When I check the voltages in the SDA and SCL lines (which should be 5 V because of the pull-up resistors) I get values close to 0.7 V. I try de-soldering the isolator and check the voltages again, with only the INA219 circuit assembled and I got another weird result the SCL line has a value of 4.8 V and the SDA line gets a result close to 0.7 V.
Can anyone help me debug this circuit?
